  #21
Old 05-05-2009, 07:33 PM
MacMillan of Rathdown's Avatar
Anytime I wear my "Episcopal Purple" braces with my trews they are hidden away behind my waistcoat.
  #22
Old 05-05-2009, 07:39 PM
ccga3359's Avatar
Quote:
Originally Posted by Cavebear58 View Post
I'd second this. A few weeks ago I stopped wearing the belt with my kilt and started using braces (as we call them here), and the comfort improvement was extraordinary. I wish I'd thought of it years ago!
The next question is what to wear to cover the gut and braces... waistcoats, v-necked sweaters, fleeces and sweatshirts all come to mind.
Cheers, Graham.
My question to those that wear them, do you sew buttons on the inside for button on or do you use the clip on style of braces/suspenders? For those clip ons isn't ther a good chance of damagaing the wool?
__________________
The Grant.
  #23
Old 05-05-2009, 08:18 PM
peacekeeper83's Avatar
Location: Cleburne, Tx is home.. but liable to be anywhere for work.
I do not wear them but I would think that buttons would be better for the kilt, I also believe the clip type would damage the wool in time.
__________________
"Ní bhíonn saoi gan locht"
"Dílis i dTólamh"
DubhÉireannach
Facebook
  #24
Old 05-05-2009, 09:16 PM
McNulty's Avatar
Steve
I like to wear my kilts up high. I'm usually at least three to four fingers above my navel. I take a 46 and wear it high. The belt is more decoration. All of my kilts are at 22 length because of my fireplug figure. Find the spot that's right for you, but remember to pull it up some.
Nulty
__________________
Kilted Flyfishing Guide
  #25
Old 05-06-2009, 06:36 AM
ForresterModern's Avatar
I use clip ons which work great in the back where the waist piece is only a sigle thickness, but not so great in the front whre you have two thicknesses becasue you have two aprons. And yes there is the possibility, depending on the design of the grippers on your suspenders, for damage to the fabric if it pulls out because of marginal grippage due to more fabric stuffed into the gripper. I have tried just clipping the front aprom, but worry the back apron may droop, but it hasn't yet.
Others have said they put buttons on the outer apron and use those with similar results, I am considering puting one button on the outer and a second on the inner apron to keep both at roughly the same height, but have not tried it yet. Still hesitant to start sewing on my expensive kilts until I build up a bit more nerve.
__________________
  #26
Old 05-06-2009, 09:56 AM
Two buttons in the back, and four buttons-- two each side-- on the inside apron. This carries the weight of the kilt, the front apron being supported by a belt on each side.
  #27
Old 05-06-2009, 11:04 AM
ChattanCat's Avatar
Steve might you be from Michigan?
__________________
and Professor
  #28
Old 05-06-2009, 01:20 PM
ccga3359's Avatar
Quote:
Would the buttons be inside or outside Sir?
__________________
The Grant.
  #29
Old 05-06-2009, 01:43 PM
Quote:
Sorry I didn't make that clear. All buttons on the inside, the same as would be the case with trousers. You might also want to check with Matt Newsome as, I believe, he may have a kilt or two in the museum with a slightly different button arrangement.
Tags
beer, belly, big guy, gut
X Marks Advertisers
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Barrel pleats Ancienne Alliance Professional Kiltmakers Hints and Tips 7 06-06-2008 09:23 AM
Measuring a beer gut for a kilt orangehaggis Kilt Advice 12 05-23-2007 02:26 PM
How much beer can a kilt hold? The-Kilted-Goth Show us your pics 34 04-09-2007 12:25 PM
Kilt got me a beer Dirk Skene Miscellaneous Forum 11 04-06-2007 02:00 PM
X Marks Sponsors
