2nd August 07, 01:50 PM
belt width for different kilts?
Hi all,
What's the minimum reasonable width of belt to use for a) a féileadh mhor, and b) a modern kilt? It seems to me that anything wide enough to look good should be OK for a modern version, as the belt isn't really needed for structural support. However, wearing an overly narrow belt with a belted plaid would seem to be somewhat...um...risky.
I would appreciate hearing from those who have some experience wearing different types of belts with kilts!
p.s., I have resolved to get a good belt from Cavscout, but that will have to wait for a bit...I'm just looking for something that will work in the meanwhile.
2nd August 07, 01:59 PM
If you just want something for now than may I suggest that you just go down to your local hardware store and buy a tool belt I did that and it has worked out great. Here is a picture of it:
I think it works fine for what it is
2nd August 07, 02:28 PM
 Originally Posted by apack
Hi all,
I have wore a belted plaid off and on for the last 10 or so years in the SCA, and have found that at least a 2" belt is a the best choice. Anything narrower, and by then end of the day I started to feel like I was being cut in half. One of the most comforable days spent in a great kilt though, was wearing a converted weight belt. It had been tooled and was quite comfy. The least was a 1" belt.
As for modern wear, I only have the belt I got from SWK, which is 2.25" wide, and so far has been quite comfy.
As always, YMMV.
James
2nd August 07, 03:08 PM
For a modern kilt, I'd say 2" / 5cm is the minimum to look right. I've worn a 1.5" belt with a casual kilt, to hold my sporran up, and it just didn't look right, at least to my eyes.
2nd August 07, 09:42 PM
A lot also depends on your size. The bigger your waist, the smaller the same belt will look. I've got a 40" waist, and I hate wearing dress belts (with pants) becuase they are usually 1" wide and look out of proportion. My casual 1.5" belt I wear with jeans looks more correct. I'd like to go even a little bigger, but they won't fit through the belt loops.
The kilt belts and buckles all seem to be 2.25" wide, but you will be hard pressed to find an alternative buckle for that width. But there are other choices such as tool belts.
3rd August 07, 01:30 AM
My kilt belts are 2" and 2.25" which seem the standard widths. If you go much different you might run into problems with getting buckles to fit. I don't think anything narrower than that would look right with a kilt anyway and as JamesA says it just isn't as comfortable.
4th August 07, 12:07 PM
I agree with the general rule of two inches.
As to the question of buckles - Some western "cowboy" style buckles work for me. The kind that some companies make to mimic the rodeo award buckles.
4th August 07, 04:21 PM
I really like the feel of wearing no belt at all with my hand sewn traditional kilts my Freedom Kilt Dress Model, and my USA Kilts semi-traditionals.
Do need a belt for my USA Kilts casuals, AmeriKilts and Utilikilts. Then I use the 2" belts AmeriKilt offers. A great value.
Whenever you order up a new kilt you HAVE to be sure to check with the kiltmaker to get the width of belt/sporran loop you want/need. Surprises lurk if you don't double check and get it clear.
Ron
PhotoBucket Album
4th August 07, 04:39 PM
I recently saw a great belt in the mens dept at a big discount store (Target)--about 2", black, with a large buckle and bottle opener right on the buckle! Great for a party or trip to the pub . . .for a dressier occasion, not so much
6th August 07, 07:34 AM
I wear about 2-2.5, for the reasons listed above.
But for my belted great kilt, I have a 4" that serves my purposes.
Barnett (House, no clan) -- Motto Virescit Vulnere Virtus (Courage Flourishes at a Wound)
Livingston(e) (Ancestral family allied with) -- Motto Se je puis (If I can)
Anderson (married into) -- Motto Stand Sure
Frame Lanarkshire in the fifteenth century
escher-Photoplog
By Sean_the_Kilted in forum How to Accessorize your Kilt
Last Post: 28th April 07, 04:17 AM
By Nick in forum How to Accessorize your Kilt
Last Post: 9th March 06, 07:24 PM
By billmcc in forum How to Accessorize your Kilt
Last Post: 2nd July 05, 04:25 AM
By billmcc in forum USA Kilts
Last Post: 30th June 05, 06:12 AM
By Anthony in forum General Kilt Talk
Last Post: 10th November 04, 09:40 AM
