Results 1 to 2 of 2
    12th December 10
    Sophomorehood, Fairbanks, Alaska
    Can I have a kilt made with a lining
    without stepping up to bespoke?
    My fiance is allergic to most wool products ;-)
    I expect to be fully satisfied with a made to measure kilt otherwise.
    Thanks
    Victoria, BC, Canada
    The most common causes for a sensitivity to wool are either dermititis caused by the follicles of the wool irritating the pores of the skin or a chemical sensitivity to the Lanolin in wool.
    If it is the dermititis that is the problem then wearing a slip under the kilt should help. Another option is to use Merino wool which is finer and has smaller follicles.
    Good Worsted wool is spun to have a minimum of follicles sticking out which cause the itching wool is known for.
    If the reason for the problem is the chemical reaction to Lanolin then no liner will help. Even normal sweat will leech the lanolin onto the skin.
    May I suggest you consider the fabric known as P/V. This is a blend of Polyester and Rayon. The fabrics woven by Marton Mills are 12 oz in weight which is just 1 oz per yard less than medium weight kilt wool. The Tartans are authentic and the colors are georgous.
    It is also very reasonable in cost.
    www.Freedomkilts.com
    2nd Laird of Lochaber
  1. Just made my first X-Kilt
    By SergeantBort in forum Contemporarily Made Kilts and How to Wear Them
    Last Post: 13th November 09, 05:22 PM
  2. My lining
    By Dixiecat in forum DIY Showroom
    Last Post: 15th July 09, 07:53 AM
  3. My Kilt made me do it!
    By Weasel Mender in forum General Kilt Talk
    Last Post: 17th May 09, 02:07 PM
  4. Kilt lining interfacing and lining.
    By I M Kilted! in forum Professional Kiltmakers Hints and Tips
    Last Post: 10th May 07, 07:38 PM
  5. first kilt made
    By filman in forum General Kilt Talk
    Last Post: 26th November 05, 06:36 AM
