Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Fabric Question
    Victoria, BC, Canada
    The Wool Tartan fabric produced by the big mills in Scotland use what is known as "Worsted" Wool. This means that the individual fibers are combed and stretched until they are all parallel. Then the yarns are twisted.
    This results in a very tight, smooth surface to the fabric. There are no little pokey bits sticking out to itch. The resulting fabric should have a hard, smooth feel to it. You should be able to see and feel each and every yarn and find where the yarns cross in the weave.
    The Fabric itself is woven in what is known as a Twill Weave. This type of weaving results in distinctive diagonal line in the Tartan Pattern.
    In most Tartan fabrics, if you have it layed out on your table with the bottom or selvedge edge towards you, the Twill lines will run from your bottom right to the top left.
    This photo show three different selvedge edges on Tartan fabric. All of them are of the outside or right side of the fabric.
    In the X Marks Tartan fabric on the lower left side you will see what we call a tucked selvedge. If you feel this tucked edge you will feel that the fabric is slightly thicker here than in the rest of the fabric. There will also be a small line of fuzz where the individual yarns are cut off. This line of fuzz should be on the bottom side of the fabric.
    BUT NOT ALWAYS!!! Some looms weave fabric by tucking the selvedge down and some tuck it up. It all depends on the loom.
    But notice that the surface of the fabric itself is not fuzzy at all.
    If the fabric you have is, or has a fuzzy surface you do not have Worsted Wool. You have some less or less expensive fabric.
    A fuzzy surface is usually a dead give-away that the fabric you have is made somewhere other than Scotland, England, or N. America.
    Please also remember this rule of Twill direction only applies to Wool Tartan fabric. Cotton Twill, Poly/Cotton Twill and other fabrics may have Twill weaves just the opposite. One is called Left-Hand Twill and one Right-hand Twill.
    www.Freedomkilts.com
    2nd Laird of Lochaber
    29th April 09
    Wichita Falls TX
    Thanks again. I'm going to be pleating rather than watching Obama's press conference.
    Jimbo
    17th July 08
    Fayetteville, NC
    You almost certainly have Acrylic. Pure polyester twill has a hard finish on both sides. It also may also be a blend with something else too. In any case, you will want the "hard" side out. In addition, there are numerous sites which go into the inner construction of the kilt. Barb's book is the gold standard, but the other sites can be helpful too.
    From your description, it seems that the excess fabric has not been cut from the pleats. In any case, good luck with the transformation
    18th February 05
    Spokane, WA
    Not all tartan fabrics go in the direction Steve suggest, but most of them do. I have kilts made in Scotland that go the opposite way. I'm still puzzled by your description of the pleats. Some photos would help.
    29th April 09
    Wichita Falls TX
    It was pleated in such a manner that it only took 2 yards to make the kilt. The pleats were very shallow and there was no attempt to follow the sett, even after I told and showed the seamstress what I wanted. So I took my pocketknife to it last week and rendered it down to its parts. I still had all of the remainder of the fabric in my closet. I just cut it all to the same length as my original kilt and then did the math from my measurements. I should have about a foot left over. I just got done folding and ironing in more than half of my pleats. An easy trick I discovered is to use a quarter, which is almost an inch across, to guage the spacing of the pleats. Tomorrow I'll sew them down and then join on the remainder to finish the last few pleats and the front apron. I want to go to the Renaissance Faire this weekend but either the rain or not finishing it will keep me away.
    Jimbo
    19th March 09
    Astatula Florida
    Sounds like you have everything under control. This board is full of excellent info. and knowledge!
    19th March 09
    Dallas, TX [N 32° 51.288 W 096° 45.978]
    Quote Originally Posted by jgcunningham View Post
    Jimbo
    Coming down to Scarby? I want to go at least once more this season, but between the weather and weddings I won't be able to until Memorial Day
    Good luck on making it down there!
    elim
  8. #18
    29th April 09
    Wichita Falls TX
    Yeah, I won't be able to get down until the last weekend. Too much rain this weekend and then busy the next two, including sitting through a 2 hour college commencement. Thank goodness for my iPhone or I would go mad during those. At least I can surf the web or play some games on it while the speaker drones on.
    Jimbo
  9. #19
    17th June 08
    Topeka, KS
    Welcome, Jimbo, from another Jim!
    I haven't heard anyone say "bassackwards" since my dad passed away almost 15 years ago. One of my favorite words.
    Why, a child of five could understand this. Quick -- someone fetch me a child of five!
  10. #20
    29th April 09
    Wichita Falls TX
    It is finished! I'll take some pics and post them on the DIYer forum. I'm pleased mightily.
    Jimbo
  1. fabric weight question
    By Howard Clark in forum DIY Showroom
    Last Post: 17th October 08, 03:26 PM
  2. Poly Viscose vs acryllic fabric question
    By Sean_the_Kilted in forum Kilt Advice
    Last Post: 11th June 07, 09:36 AM
  3. pinstriped fabric question...
    By cloves in forum Professional Kiltmakers Hints and Tips
    Last Post: 27th October 06, 10:06 AM
  4. Fabric question
    By Doc Hudson in forum General Kilt Talk
    Last Post: 16th July 04, 08:50 AM
  5. Fabric Question?
    By Miah in forum Kilt Advice
    Last Post: 22nd June 04, 08:14 PM
