Results 1 to 10 of 19
    Celticman's Avatar
    Celticman is offline This registration voided by member's choice.
    8th June 05
    Lafayette, LA USA
    Smile Has anyone had a dress, pleated-to-sett kilt resized?
    Hello all,
    I have a question about having a dress kilt resized. I have lost a bit of my beer-belly (despite my best efforts to maintain it) and my kilt is a bit large in the waist. As it is right now I am sinching up the kilt on the last hole in the buckles and it is still a wee bit loose. So, I was planning on taking it to a seamstress to have it taken in a bit.
    I don't know anyone who has had this done so I don't know if this is going to be worth the effort. Since a nice kilt is rather expensive these days I would rather have my kilt refitted rather than purchase another one. However, I would rather spend a bit of money to have a kilt that I am proud to wear than to wear a kilt that looks sloppy.
    Any thoughts?
    [CENTER]--------------------------------
    Cha bi neoni lathair gun seorsainn
    (Nothing of value can survive without freedom)[/CENTER]
    15th August 04
    Kilts are easy to take in or let out. Some folks here might even know who you could send your kilt to to have it done.
    It shouldn't be a problem at all.
    Celticman's Avatar
    8th June 05
    Lafayette, LA USA
    Thanks for the input...I was not sure if it could be done or not.
    Some advice would be helpful as to whom to send my kilt to. I will search the local area to see...but, if it's as "easy to take in" as you say it is I'm sure any seamstress should be able to do it.
    Again, thanks for the help.
    15th August 04
    Actually, for taking it in a bit, all you would need to do is pop your buckles back a notch or two and sew them in place.
    I think.
    Hmm?
    Celticman's Avatar
    8th June 05
    Lafayette, LA USA
    I thought about doing just that, but the holes where the belt slips through the fabric would either bunch up (and, thus, look bad), or would not line up at all. Besides, I am not confident enough in my sewing abilities to do that, but I will definitly suggest that to whoever I send it to to be altered.
    6th May 04
    Mississippi Delta
    On the right side, move the buckles. On the left side, move the strap.
    Of course the easiest method would be to just regain the weight.
    3rd September 04
    I don't mean to be discouraging, but there's something important to note.
    I'm currently taking in a 'tank' for a friend in the same situation [lost the beer belly], and just moving in the belt/buckles won't result in a proper fit. His seat measurement stayed the same, and his belly came in over 4 inches - that changes the amount of taper required dramatically, and is a pile of work.
    If he weren't a friend, I'd charge him like crazy for it, because it's most of the way towards building a new kilt [only with the wrong lines already pressed in].
    Now, that said, moving the buckles and belt [and yes, you can totally do it yourself if you try] will keep the kilt from falling down, and won't look terrible. It all depends on what you want. If you're trying to save money, try the simplest option first, and see if you like the results.
    Celticman's Avatar
    8th June 05
    Lafayette, LA USA
    Ya...I was afraid of that. I thought about that and I don't see any easy way to make the proper alterations without taking the kilt completely apart. It appears that my best option is to sell this one and buy another.
    Hmmmm.....
    bubba's Avatar
    14th February 04
    Little Chute, Wisconsin
    An inch or 2 you can get away with just moving straps and buckles, but more than that it won't look good.
    chasem's Avatar
    chasem is offline This member has been inactive for more than 1 year
    30th March 05
    Near Santa Fe, New Mexico
    what size is the current kilt?
