2nd November 04, 02:41 PM
HELP! Kilt newbie needs advice to keep b***s off chairs!
OK so I put on my Amerikilt. I decided to try a few common postures in the house first before I go out into the world with confidence.
My first major hurdle: sitting down. OK so the front apron drops down if I'm mindful. But the rear pleats ride up... WAY up. My b***s are right on the chair. Not good. It seems like no matter how I try to sit, I've got direct contact with the chair where there should be no direct contact. Advice?
2nd November 04, 02:49 PM
you hve to aproach all sitting diffrently or I did atleast.
I had to smoth the pleats before i sit, and most of the time I sit from the side. I make sure the pleats are under me as I sit
It is hard to explain maybe somebody else can explain it better. But where in relation to you knee cap does the kilt land when you are standing up ?
2nd November 04, 03:02 PM
I've noticed this phenomenon too. I don't have a good answer other than to wear underwear. I know for some that will defeat the purpose but there are some places, such as at a movie theater, that I just don't want to be sitting bare. I'm also curious if someone has some idea I've overlooked.
Quondo Omni Flunkus Moritati
Viscount Bikercelt the Bloody of Much Madness upon Avon
2nd November 04, 03:05 PM
takes practice, I dunno how to explain.
but sometimes it's b***S on the chair, no other way to do it.
don't do what I did, pull the back down too far, and I ripped the pleats,as I sat on them
only popped a few stitches but p!$$ed me right off.
anyway, better to get sweat on the pub chairs then ur kilt 8)
because I can
2nd November 04, 03:10 PM
It seems I have the wrong size. Too short. I gotta call Mike and get this straightened out. He said it shouldn't be a problem to return it if it doesn't fit right.
2nd November 04, 03:20 PM
OK here's the deal. I never had a kilt before so wasn't too sure on logistics. Got some advice from Mike@Amerikilt and hoping to get a hold of him to straighten this out.
I measured from top of where I normally wear my jeans down to floor from a kneeling position. Came up with 21". He had 20" and 22" lengths. I ordered 20" thinking a 22" might cover my knees. On the contrary. 20" length really measures 19" and with the belt on it tightens up a little to 18" length.
Couldn't raise Mike on the horn. Left a msg. Hoping to get this resolved amicably.
2nd November 04, 03:24 PM
Wow 18" yeah unless you are about 5'6" that is way short!
2nd November 04, 03:32 PM
I'm 6'1" but taking his advice the idea was that I would wear it down on the hip because I have a big belly.
I'm thinking along the lines of just returning it for a refund and seeing Rocky @ USAK (ASAP) since he's got a storefront and can measure me himself so I'm sure I'm getting it right. When I'm sure I have a good set of measurements from a pro kiltmaker that will make me more confident about ordering online again.
2nd November 04, 03:43 PM
A kilt that short is certainly going to exaggerate the problem, but it seems to me that the problem of contact with hot/cold/unpleasant surfaces can happen even with a kilt the proper length.
2nd November 04, 03:58 PM
