17th October 11, 01:02 PM
How high is too high?
I've read many a discussion on length. Above, mid or below the knee. I think we all know where that discussion currently rests.
My question is height above the waist or navel. Some disagree with kilts sitting too low, like jeans, but we seldom talk about how far above the navel.
Your thoughts?
17th October 11, 01:09 PM
Re: How high is too high?
My thoughts are that the narrowest point around the kilt, usually the stabilizer and straps, will sit at the natural waist. If the kilt has a rise above that of two or ten inches that will be how it will end up on the wearer's body. I had to fix my wool kilt to sit properly and it made a huge difference in comfort.
I'm not a kiltmaker etc.
17th October 11, 01:26 PM
I have one kilt with a 4" rise, ie I wear it 4" above my navel, while the bottom of the front apron falls just below the top of my knee. It's an 8-yard, wool heavyweight (a tank), so it helps keep me warm in our snowy winters. Each of my other kilts has a 2" rise.
Armpit high is probably too high, but I suspect there is somebody, somewhere donning such a kilt as we write.
Numquam ubi, sub ubi
17th October 11, 01:39 PM
17th October 11, 02:05 PM
One thing that I try to stress with my customers is not to use their naval as a guage for the height of their kilts.
Depending on your body shape the level of your navel may be different than someone with a different body shape.
Kilts that are made in the traditional manner, the Fell or sewn down and tapered area in the back, is not a straight line. It tapers smaller till it gets to the level of the top straps, It them flares back out above the straps. This means that the smallest part of the kilt is at the top strap.
This style of kilt is worn at the natural waist. To find your natural waist turn your hand so your spread fingers point towards your back. Place your hand with your fingers on your spine and your thumb at your side just under your ribs.
Then bend sideways towards your thumb. You will feel your thumb go into a depression or hollow just under your ribs. That is your natural waist. It is the smallest part of your body and where you cinch the straps.
If your kilt does not have this two way taper then you must adjust it till the smallest part of the kilt is worn at the smallest part of the body.
Now, if you do not have a Traditional style kilt, if you wish to wear your kilt at other than full rise, then the best thing to do is find where the waistband of your kilt would fit best given your body shape.
This is most easily done with a strap or belt. Put the strap around your self where it feels comfortable to you. Snug it up a bit but not tight enough that it cannot move. Then slide it side to side. Allow the strap to move till it is laying where it naturally wants to fit on your body. If you then put your kilt on at this level it will stay in place quite naturally.
Again, do not use your navel as a referance. I tell my customers to pay attention to their back, near the spine. There are three places on the body that are sort of natural for a waistband to lay. One is up at the natural waist (or if you will up at kidney level.)
The next place is into the small or nape of the back. To find this place back up to a wall, reach behind yourself and find where your spine if furthest away from the wall.
This is what I call 'mid-rise'. At mid-rise the waistband will usually sit just on top of your hip bones. A kilt worn at mid-rise can fit quite loosly as it is supported by the hip bones.
Low rise I define as 'Jeans waist'. The waistband of the kilt will sit on the flare of the butt in the rear and at the sides be below or over the hip bones.
Notice that the three levels are not referanced to the navel. They are found where a belt would fit naturally on your body. Where ever that is.
www.Freedomkilts.com
2nd Laird of Lochaber
17th October 11, 02:24 PM
Steve: Thank you for your interesting and thoughtful analysis. It brings new meaning (to me, anyway) to the term "rise".
I make reference to my navel, because it is so much easier to find. I just look down and say, "Oh!, there it is."
Now, you've made my life more complicated.
17th October 11, 02:39 PM
Your thoughts?
Generally it's important to concentrate on where the kilt falls on/or above the knee, wherever the top of the kilt stops really isn't so very important, as every kiltmaker has slightly different ways of making, and will also probably have different measurements of rise.
Steve's point's are well taken but they may not be universal, for his kilts perhaps and his chosen method of measuring, but it might not neccessarily hold good for all kilt makers.
BOOKBINDER & KILTMAKER
Traditional and Modern
17th October 11, 03:22 PM
Proportion has got a lot to do with how well a kilt will look when worn high mid way or low on the body.
Trousers look alright when worn low because there is still a lot of them - though there can be a distinct ice cream cone effect when worn low and tight.
I think a kilt can look very wrong when it appears to be wider than it is long - what I think of as the pelmet effect. (A pelmet is a gathered strip of fabric which is hung at the top of a window to hide the curtain rail.)
A few inches of rise alters how the body shape is perceived.
Anne the Pleater
17th October 11, 05:13 PM
Oh, I thought you were only talking about traditional kilts... My canvas kilt is mid rise and the top, the straps and above, rests just above the top of my pelvis bones. It's not really built like a traditional kilt, though.
* There's a four inch wide, internal waistband made from very thick canvas that flares toward the bottom a little and fits around the pelvis bones. The outside of the kilt, at the top, is attached to the top of that waistband and hangs down from that point.
Hope that makes sense.
17th October 11, 06:06 PM
Good thread! I've always been extremely confusticated by this issue...
Here's tae us, Whas like us... Deil the Yin!
Last Post: 1st May 10, 06:27 AM
By funlvnman in forum Miscellaneous Forum
Last Post: 26th August 08, 08:54 PM
By greenguzzi in forum Kilt Advice
Last Post: 25th March 08, 02:44 AM
By Rex_Tremende in forum Kilt Advice
Last Post: 12th May 06, 09:19 AM
By Iolaus in forum General Kilt Talk
Last Post: 13th March 06, 10:26 AM
