Old 01-25-2005, 10:39 AM
beerbecue's Avatar
Instead of two halves..........
Instead of 2 equal lengths for making a kilt, could one use three equal pieces, and have two splices within the pleats?
Trying to use up matching remnants....
Old 01-25-2005, 01:03 PM
The Wizard of BC's Avatar
Owner/Kiltmaker
Sure, why not.
The reason it is usual to use two pieces is that you usually buy one piece half as long as you need and rip it into two.
There is no reason you couldn't piece each pleat if you REALLY had to.
Just be careful to get the pattern aligned perfectly.
__________________
www.Freedomkilts.com
2nd Laird of Lochaber
Old 01-25-2005, 04:12 PM
Jimmy Carbomb's Avatar
Steve's right... again. In fact, you can use any multitude of pieces as long as the seams are deep in the pleats. I know one kiltmaker that actually uses one piece for the front apron, one for the pelates on the left, one for the pleats on the right, and one for the under apron. The pieces are already surged and in-stock for assembly. The differenct waist sizes will determine which length of piece is used for the pleats.
I would not suggest it, but I've seen one kilt that had alternating pleat colors (green, white and gold). the work to join all that must have been a real pleasure.
Old 01-26-2005, 05:17 AM
Barb T.'s Avatar
Author of "The Art of Kiltmaking"
Yup! I've had to do this on occasion when someone brought me tartan but didn't order enough. It'll work as long as the dye lot and weave is the same.
If you're using tartan, just be absolutely sure that the twill line goes the same way in all pieces! I once saw a kilt that had a reverse in the twill line at the seam. Ugh.
Cheers!
Barb
X Marks Advertisers
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
X Marks Sponsors
