Results 1 to 10 of 10
Thread: Kilt Rise
    3rd July 09
    Bethlehem, PA
    Kilt Rise
    I've searched the site but couldn't find an answer so hopefully someone hear can. What is kilt rise? I know that a 2" rise is considered "civilian" and a 4" rise military, and that the military wear the kilt higher on the torso, but what is the rise exactly? What is the real difference between a 2" and 4" ( other than the obvious 2 inches ).
    8th February 04
    The rise is the distance from the center of the buckle (the swing arm) to the top of the waistband. The buckle cinches in at your true waist (basically your navel). The RISE is the section above that point.
    To clarify another similar question...
    DROP is the measurement from the top of your hip bone (your waist) to the middle of your knee.
    RISE is the 2" measurement above that.
    LENGTH is the FULL distance from 2" above your waist to the middle of the knee.
    Put into a math equation:
    Drop + Rise = Length.
    PLEASE NOTE: Some kilt companies ask you to take your measurements different ways... some ask for DROP while others ask for LENGTH. Always follow the instructions of the company you purchase from.
    Also... Welcome from Phoenixville PA!
    Rocky Roeger
    Owner & Kiltmaker
    www.USAKilts.com
    8th March 09
    Rocky is a kiltmaker... nothing else need be said..
    "Ní bhíonn saoi gan locht"
    "Dílis i dTólamh"
    DubhÉireannach
    Facebook
    1st December 06
    Conyers, Georgia
    Yeah, if Rocky says it about a kilt, it's like reading it in the Bible.
    Jim Killman
    1st December 08
    Montgomery Alabama
    Quote Originally Posted by jtmilisits View Post
    ditto rocky
    May you find joy in the wee, ken the universe in the peculiar and capture peace in the compass of drop of dew
    3rd July 09
    Bethlehem, PA
    Thank you. That answered my question perfectly.
    14th January 08
    Goshen, KY
    At first read of the thread title I thought this thread had some sexual connotation but I see it is a legitimate kilt build concern. Pardon my intrusion.
    22nd November 07
    Desert SW USA
    There is one other aspect of the rise. It has to be able to flare out at the top. That is, the very top of the kilt, at the waistband, has to be wider than the waist area where the buckles are, when the kilt is being worn.
    On a two inch rise, this can be achieved by stretching the top of the kilt as the waistband is being sewn on. This is how Barb T. has explained it on the forum. This is opposed to a Stillwater kilt, for example, which is tapered all the way to the top, and the waistband is the tightest point of the kilt.
    I am not sure how a four inch rise is constructed, but suspect that it requires some extra flaring to be built into the pleats in the rise area. Perhaps a kiltmaker could explain that detail.
    8th February 04
    Thumbs up
    Ted is correct... the pleated section ABOVE the rise should either flare out or at least be straight up and down. The fell should never taper all the way to the top on a traditional kilt.
    The reason it does this is for comfort and fit. The buckles should cinch tightest at your skinniest point (true waist). The flare is to allow for 'expansion' above the waist and to avoid kilted 'muffin top'. If you're unaware of the term muffin top, ask your closest female (it's used while talking about tight jeans).
    For those confused by this whole thread, here's a simple visual... the fell of the kilt (and each pleat for that matter) should have a VERY subtle hour glass shape with it being slightly wider at the waistband and bottom of the fell than at the middle of the buckle. If the person is a bit skinnier, then it will be straight up and down for the top 2" and then bell out as you go down the fell.
    Rocky Roeger
    Owner & Kiltmaker
    www.USAKilts.com
    25th August 06
    South Wales UK
    Well done Rocky for rising to the occasion.
  1. Of the Military (Kilt) Rise
    By BoldHighlander in forum General Kilt Talk
    Last Post: 3rd September 09, 05:53 PM
  2. What size the rise?
    By Kiltman in forum Professional Kiltmakers Hints and Tips
    Last Post: 30th December 08, 06:25 AM
  3. Why the rise in kilt popularity?
    By Sionnach in forum General Kilt Talk
    Last Post: 9th October 08, 11:29 AM
  4. "Low rise" kilt question
    By ConfusedPollock in forum DIY Showroom
    Last Post: 30th July 07, 07:41 AM
  5. Will the defense please rise?
    By Tattoo Bradley in forum General Kilt Talk
    Last Post: 28th January 07, 05:50 AM
