Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
    4th August 06
    rison, arkansas
    Quote Originally Posted by Bob C. View Post
    If you're bujying a new kilt, get the kilt you want - not onje geared for the weather on one particular day.
    Now, some personal preferences that will rankle some folks here: I prefer the brighter modern colors to the faded ancient ones and find most hunting tartans to be less attractive than their regular counterparts.
    Box-pleated kilts remind me of my daughter's cheerleading skirt.
    Take that for the little it's worth. We all have preferences. Go with yours.
    Nice to know I'm not the only one that thinks like this. I agree 100% with everything he said.
    Knowlege is knowing that a tomato is a fruit; Wisdom is knowing not to put it in a fruit salad
    Quote Originally Posted by Dreadbelly View Post
    If people don't like it they can go sit on a thistle.
    Chef's Avatar
    Chef is offline This member has been inactive for more than 1 year
    27th October 06
    Long Island, NY
    Agreed with the caveat that it work for the weather where you will wear it most of the time.
    I like both the weathered/ancient and the modern colours. However I tend to wear my Ancient Hunting Stewart of Appin more during the day since those colours lend themselves to brown. I prefer the modern colours for evening.
    While I don't know about the cheerleading skirt bit, I'm not a fan of the box pleat either.
    ckelly327's Avatar
    ckelly327 is offline This member has been inactive for more than 1 year
    22nd March 06
    Albany, NY
    I have a 16 oz 8 yarder, 100% wool and live in upstate NY. I've worn it in the summer as well as when it was snowing and never felt that it caused me to be any warmer or colder than my choice of jacket or shirt. Kilts seem to be very forgiving of weather. I agree that you should get the kilt you want regardless of one ocassion on your calendar. Ennjoy the day and the kilt.
    So fill to me the parting glass
    Good night and joy be with you all
    M. A. C. Newsome's Avatar
    Contributing Kilt Historian
    26th January 05
    Western NC
    On the question of what style of kilt you want and what tartan you want, both of those ultimately fall into the category of your personal preference, so all I can tell you is to get what you really want.
    I can advise a little bit about the cloth weight, though. And I will give you my usual advice, which is to get the heaviest weight that is available in your budget.
    To determine that, you first need to select your tartan, because not every tartan is available in every weight range. For instance, MacKinnon modern and MacKinnon Hunting ancient are both available in 16 oz cloth from Lochcarron, but the MacKinnon Hunting ancient is priced as "rare select" which means the cloth (and therefore the kilt) will cost a bit more.
    Both these tartans are also available from Lochcarron in their 13 oz cloth.
    And from the House of Edgar, MacKinnon Hunting ancient is available in both 13 and 16 oz. MacKinnon modern is available in an 1821 variant, in the 13 oz only.
    Now I have only checked from these two mills, but already you see that with this particular tartan you have lots of options, which is a good thing.
    While both 13 oz and 16 oz will do fine in a 4 yard box pleated kilt, I strongly reccomend going with the heavier weight in this style where it is available. It really makes more of a difference in kilts with less yardage especially. Both the tartans you mentioned are available in 16 oz, and I don't charge any different between the two weights (except for "rare select" tartans, which are about $25 more), so really there isn't any reason to not get the heavy weight.
    If you are concerned about heat, remember that this style of kilt only uses 4 yards, rather than 8, so you are cutting down the amount of cloth drastically, meaning that even a heavy weight 4 yard kilt is likely to feel cooler than a light weight 8 yard kilt will. Also, as Barb has pointed out, it's not so much the kilt that makes you warm, it's the woolen hose, woolen bonnet, woolen jacket, and all the other accessories we pile on top of the kilt.
    If you decide on a tartan that's only available in 13 oz (like the 1821 variant the Edgar weaves) that's fine. It also makes a good box pleated kilt, and it's much more important to get the tartan you really want rather than worry about an extra 3 oz per yard kilt weight.
    If you get a 5 yard knife pleated kilt, ditto for all I said above about box pleated kilts.
    If you get an 8 yard kilt, the same advice applies, but to a lesser degree. I still say get the heaviest weight available that is within your budget. And while *I* would certainly still prefer the 16 oz due to the look and durability of the fabric, I know some people would be more comfortable in a 13 oz or lighter. In an 8 yard kilt, it's going to make less of a difference than in a 4 or 5 yard variety. For instance, I will sell you a 10 oz 8 yard kilt if that is what you really want. It's not the best cloth for a kilt, but it works if that is what is available. But I will not sell you a 10 oz 4 yard kilt! I'll have the cloth custom woven in a heavier weight first if that is what I need to do.
    I hope that helps. If you have any other questions about selecting your kilt or tartan, feel free to email or call.
    Aye,
    Matt
    Matthew A. C. Newsome, GTS
    27th October 06
    Snellville, Ga
    Thank you Mr. Newsome for your advice. I actaully plan on driving up to NC in the next couple of weeks to see you and place the order for whatever I decide. I was quite impressed with the time you took during the Stone Mountain Highland Games to answer the questions I had on the Kilt and the difference between the box and knife pleats. I guess my concern comes down to the fact that the wedding party will likely all be in 8yd knifes and I am not sure that a box pleated would fit in....
    Anyway, I am almost certain that I would be looking for the MacKinnon Hunting Ancient as the tartan.
    Mike
    19th May 05
    SF Bay Area, CA
    I think you should get whatever tartan you want/prefer, but that said, a hunting tartan would not be my first choice for a wedding, particularly if there was a nice dress, modern or weathered tartan I liked too. I know the weathered and dress tartans are usually lighter colored than the hunting, but with a PC or dark Eton jacket, the light colors give better balance and tend to stand out more, particularly in photos.
    JMO.
    ~Mark in CA
    www.KiltDay.com
    motorman4life@gmail.com
    > Remember.. if anyone asks you why you are wearing a kilt.. look at them like they're crazy and say, "Don't you know it's Kilt Day, today?!"
  1. Wedding kilt
    By arrogcow in forum General Kilt Talk
    Last Post: 15th November 06, 11:25 PM
  2. Wedding!
    By Tattoo Bradley in forum Miscellaneous Forum
    Last Post: 16th July 06, 12:01 PM
  3. Wedding Day
    By eighties in forum Show us your pics
    Last Post: 26th May 06, 11:40 AM
  4. Need a kilt jacket for October wedding...
    By MacSimoin in forum Kilt Advice
    Last Post: 11th February 06, 08:43 AM
  5. From my wedding
    By Bob C. in forum Show us your pics
    Last Post: 6th June 05, 12:53 PM
