Results 31 to 38 of 38
  1. #31
    14th August 07
    Halifax, NS
    Quote Originally Posted by kender View Post
    Is this an issue because the pleats are independent from each other or is it the fabric actually stretching? If the pleats are sewn together at the top, similar to utilikilts, does the same thing happen?
    The issue is that the belt is cinched to fit the waist of the wearer and it's pulling the kilt out of the position to which it had been made to fit because the belt is through the loops. It is also putting too much pressure on the bottom of the loops and actually pulling the fabric up at those spots 'pooching' the fabric out at the bottom as it were.
    If the belt were worn overtop of the kilt and not through the loops, you wouldn't see the issue that Barb has pointed out.
  2. #32
    14th August 07
    Halifax, NS
    Quote Originally Posted by Rabbi_Pazo View Post
    Beelts loops are not a traditional part of a kilt. In addition, a pipers kilt should have only ONE waist belt on each side; two in total, while a Dancer's kilt has the afrementioned two, plus and additional belt and buckle on the Upper apron, right below the right side waist belt and buckle.
    Unfortunately, a great number of pipesr wear dancers kilts, and don't even know it.
    As proven in another thread, while dancers are required by dress code to have three straps/buckles, a kilt HAVING three straps/buckles doesn't automatically make the kilt a dancer's kilt.
  3. #33
    4th November 10
    Arizona
    Quote Originally Posted by Canuck of NI View Post
    And logically, for us neutrals the only safe compromise is to use one loop for the belt and the other for the sporran.
    That's being P.C.! Haha!
    [-Floreat Majestas-|-Semper Vigilans-|-Aut Pax Aut Bellum-|-Go mbeannai Dia duit-]
    "I consider looseness with words no less of a defect than looseness of the bowels." - John Calvin
  4. #34
    14th January 11
    Langley, BC, Canada
    Quote Originally Posted by Tony View Post
    Are there actually pants sites to provide a forum for discussion of such intricacies?
    Yes. Yes there are... and occasionally they discuss kilts as well.
    http://www.askandyaboutclothes.com/forum
  5. #35
    13th November 08
    Milwaukee, Wisconsin
    When I first became a Kilted Gent I was Informed that the loops were there to help you hang it up after you took it off. Our Pipe Sergent some 20 years ago would yell at any piper who used them for there belt.
  6. #36
    17th January 11
    D/FW, Saginaw area
    It's my understanding that belt loops are a modern thing. They're not necessary as belts are ornamental only. Still, if you've belt loops and don't put the belt through them, you run the risk of good-intentioned people telling you that your belt is out of their loops.
    [SIZE="1"]Beauty is in the eye of the beerholder
  7. #37
    24th June 08
    Aberdeenshire, Scotland
    My kilt, supplied by a long-established kiltmaker in Aberdeen, has loops - but I am seriously considering removing them because it is a faff to put anything through them. Anything I should be aware of before attempting this?
    Gingerpose
    insert signature of your choice here
  8. #38
    20th January 11
    Muskegon, MI
    I wore my kilt out on Friday night and did not use the belt loops. I was worried that my sporran strap would slip. Never did. The loops are coming off.
    501st Legion - Kilted Trooper Brigade
  1. What Are the Two Loops on Kilt Belt?
    By Galb in forum Kilt Advice
    Last Post: 6th May 08, 01:13 PM
  2. Belt through loops or over?
    By Standard in forum Kilt Advice
    Last Post: 7th February 08, 09:28 AM
  3. Belt Loops
    By SnakeEyes in forum How to Accessorize your Kilt
    Last Post: 31st January 07, 08:25 PM
  4. Belt Loops on Kilts - Why?
    By MACKAY in forum How to Accessorize your Kilt
    Last Post: 24th July 05, 10:11 AM
  5. UK Belt Loops
    By Galant in forum Contemporarily Made Kilts and How to Wear Them
    Last Post: 4th March 05, 01:34 PM
