Results 1 to 10 of 16
    mymetaforisbigerthanyours is offline This member has been inactive for more than 1 year
    31st March 08
    KC-MO-USA
    possible solution to wind problem
    I am in the process of making my second kilt, and because my first one was a little too suceptable to wind for my comfort (or anyone elses), i am thinking about doing it a little differently this time. I have allready decided to use a tougher fabric and to sew in the pleats, but my question is this-
    would it be a bad idea to sew small weights (like what might be used for fishing) into the hem to make it less... sail-like?
    look! its a bird! its a plane! its blatant missuse of pharmicudicals man and his sidekick placebo boy!
    23rd April 05
    South Chesterfield, VA
    I've thought about that too; but, there are many good kilt pin options for the apron.
    Welcome from West Virginia!
    Every man thinks meanly of himself for not having been a soldier.
    ~Samuel Johnson
    People don't like to be meddled with.
    ~River Tam
    Dirk Skene's Avatar
    Dirk Skene is offline This member has been inactive for more than 1 year
    16th August 06
    Memphis, Tennesee
    No advice but from Memphis, Tennessee. Home of the blues & Elvis.
    Grand Duke Dirk the Festive of Hope End
    If this is the men's department, where are the kilts?
    25th January 08
    Berkeley/Livermore CA
    Sewing in the pleats is a good idea; more than anything else, it makes things much easier to press. Heavier fabric will help. 8-10 oz. range is fine for cotton or cotton/poly. One could sew a drapery weight into the apron bottom, but a kilt pin might be all that you need, (and it is attractive too).
    Michael the Farlander
    Loch Sloy!
    31st January 08
    From Liverpool UK, now in North Carolina
    I've read elsewhere of someone doing the weight thing but unfortunately don't know whether the results work. I'm far from being any sort of expert but my gut reaction would be that if you're making the kilt yourself and you know you can (a) hide the hem; and (b) not change the way the kilt hangs then why not go for it? If nothing else you'll feel more comfortable knowing there's a little extra something there. Personally I haven't found my kilt pin (just a standard one from SWK) helps a hell of a lot, just a little. Nevertheless I still wear it
    The trouble with having an open mind is that people will insist on coming along and trying to put things in it - Terry Pratchett
    Arizona Scot's Avatar
    Arizona Scot is offline This member has been inactive for more than 1 year
    21st August 07
    San Clamente Ca
    No advice on your subject just wanted to say hello and welcome to the rabble.
    "Do not demand what you can not take."
    "Sonoran Scotsmen California Chapter"
    2nd July 06
    Madison, Wisconsin
    Some pipers sew in fishing weights to keep their kilts down while they're busy piping.
    -Greg Long
    Whisky Buyer, Vom Fass USA
    31st January 08
    Oh, I forgot to say
    12th November 07
    NC
    I can't help, but welcome to the rabble!
    'Cause every lass goes crazy 'bout a sharp dressed Scot!
    Kilted metalhead!
    14th January 07
    Welcome
    If you add weights be careful where you place them. If you bounce the weight off your leg with every step it could be a very, very long day.
    Perhaps some "lead" sheeting cut into small squares. In this way there would not be a bump of weight bumping your leg.
    Let us know how it works.
  1. wind
    By belsen in forum General Kilt Talk
    Last Post: 19th January 08, 01:16 PM
  2. spouse/kilt troubles? I have hit upon the solution.
    Last Post: 14th December 06, 12:02 PM
  3. Temporay Closet shrinkage Solution
    By Bill in forum Kilt Advice
    Last Post: 23rd May 06, 06:53 AM
  4. Wind in the Hair
    Last Post: 24th December 04, 11:19 AM
