Results 1 to 10 of 28
    problems with the top half
    I know the question of what to wear with the kilt (jackets, sweaters, rugby shirts and what have you) has cropped up often before, in various guises.
    At a short 5'6" (and 130 lbs), I've found I hardly own anything that goes well with my kilt. Practically all of my T-shirts and polos are at least hip length and just look dreadful. Far too long. Same goes for sweaters; either too long or too slim fitting (that heavy Cameron kilt puts a good couple of inches on my hips and behind - anything slim fitting makes my hips look far wider than my chest. Unflattering). All I have is one ancient shrunk white T-shirt, one fairly short and boxy grey sweater and a hip length beige rain jacket. Not overly stylish really.
    I can't really wear shirts or T's on their own tucked into the kilt either - it's military cut and reaches well up to my ribcage. I would look like a tartan lampshade.
    So what's the answer, fellow short guys? Shell out for a properly cut kilt jacket? Waistcoat? Have a few T-shirts shortened?
    I am desperate for ideas - going out kilted tomorrow evening (yippee!), casual but don't want to look sloppy!
    M.
    3rd June 05
    The beautiful Catskill Mountains of Upstate New York
    I posted this in another thread, so my apologies to those who have seen it:
    Tuck in your damned shirt. Don't be a slob.
    Blu (Ontario)'s Avatar
    Blu (Ontario) is offline This member has been inactive for more than 1 year
    22nd January 04
    Southwestern Ontario
    You might try wearing the shirts and polos - tucked in. I think that if a shirt is not tucked into the kilt, it just looks sloppy. Bomber style jackets work... and a jean jacket might be worth a try if its short enough.
    good luck.
    12th April 06
    Kyle, Texas
    Yup... what they said.
    2nd April 05
    Smyrna, Tennessee, USA
    Quote Originally Posted by Bob C.
    I think we could be a little more helpful. Moose has said that he has a military cut kilt that comes up to his ribcage. So if he tucks in, he looks off balance because of his (lack of) height.
    Moose,
    Can you post a picture of yourself, tucked and untucked? It might not be as bad as you think. Would if be possible to hem the kilt so that you don't have to wear it so high? An inch or two could make a big difference.
    Sweaters are not normally tucked in. If its too long try pulling the bottom of the sweater up higher and letting the excess roll over. Just work with it until it looks right.
    If you do tuck in, a vest of some kind might break up the line between your kilt and shirt. You probably wouldn't even have to button up the vest. And a leather vest might give you a good casual look with a T-shirt.
    I hope that helps.
    Heath Barkley
    Clan Barclay International - Pres.
    Thanks for the tips!
    Tucked in is fine with me (always, with shirts) - and I always thought the convention with T's and especially polos was untucked. Sweaters or waistcoats untucked too, obviously. It's just difficult finding something short enough for on top, in waist to hip length
    Now I just wish I hadn't thrown out my old jeans jacket years ago!
    The rise on my kilt is just too high to look good on its own I fear, at 2" above my navel. Might just go for the shirt (tucked in, don't worry) and black suede waistcoat on top.
    M.
    Quote Originally Posted by HeathBar
    Moose,
    I hope that helps.
    Thank you HeathBar, you indeed hit it exactly on the head with "off-balance" - that's how I should have phrased it myself. The kilt is too heavy to be hemmed and would not go further over my hips in any case. Luckily it's a good fit, albeit on the outer holes of the straps.
    Good tips with vest and sweater too.
    I'll get pics up, don't worry, but not until I look presentable. Don't want to end up on that "Kilt Dos and Don'ts" thread. :-)
    M.
    arrogcow's Avatar
    arrogcow is offline This member has been inactive for more than 1 year
    24th October 04
    Cincinnati, Ohio
    Don't just tuck, once the kilt is on, try pulling about 2 inches of the t-shirt out evenly all the way around. The blousier (SP) look might work with a kilt with that high of a rise.
    Adam
    "Down among the dancing quanta, everything exists at once." - Warren Zevon
    bubba's Avatar
    14th February 04
    Little Chute, Wisconsin
    Moose, this is my usual look with a military cut kilt. It's the Cameron from What Price Glory.
    billmcc Guest
    Quote Originally Posted by Moose McLennan
    A traditional kilt should be worn with a 2-inch rise above the navel. (A military kilt is worn even higher.) If the top of your kilt looks too high, it may be your belt isn't wide enough. A Scottish kilt looks best with a 2-inch or wider belt.
