Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
  1. #21
    24th January 07
    Moreno Valley, California, USA
    Has she never handled one of your kilts? That's too bad. Hopefully you can find a home for that one.
  2. #22
    30th November 04
    Deansboro, NY
    What's the weight of the tartan?
    B
  3. #23
    14th September 05
    Space Coast, FL
    Barb, that is a great question! And I wish I had a definitive answer. It appears to be a bit heavier than my SWK heavyweight Weathered Lamont, if that tells you anything. It also seems to be heavier than the last batch of XMarks, which was 14oz. I believe? Thos are the only 2 I can compare it to that might give you an idea (although I just spent 10 minutes in my closet fondling the scrap piece in one hand while I compared it to all my other kilts with my other hand!). I suppose I could try to lay a yard on my postage scale, but that is probably only going to be a very rough approximation.
  4. #24
    4th August 06
    rison, arkansas
    My g/f wanting a pink and black plaid mini kilt now, thanks KCW. lol
    Knowlege is knowing that a tomato is a fruit; Wisdom is knowing not to put it in a fruit salad
    Quote Originally Posted by Dreadbelly View Post
    If people don't like it they can go sit on a thistle.
  5. #25
    30th November 04
    Deansboro, NY
    Quote Originally Posted by KiltedCodeWarrior View Post
    Huh - I'm surprised - tartan with such a small set is typically light weight tartan.
    You could try telling her that, until you cut out the bulk at the waistline where the pleats are, it will feel bulky, even if it's lightweight tartan. This is particularly try in the case of this kilt because the pleats are so deep and there's so much overlap. Once that's done, and the kilt is actually buckled on, it won't feel heavy or stiff at all.
    B
  6. #26
    30th November 04
    Deansboro, NY
    Barb, I have done a couple of right over left apron kilts and there is really no need to reverse the pleats. Everything works fine. In fact with the pleats facing right over left the apron looks quite good. The only problem I found is the right edge of the new under apron sometimes catches on the underside of the reverse pleat in a stiff wind or if you run or dance.
    Just did a little sleuthing on kilt skirts, and the ones I found actually are complete mirror images. Not saying it can't be done the other way, but apparently people who make kilt skirts (which I don't, hence my ignorance!) typically have the pleats opening the other way. So, if I had to make a choice, I'd be likely to reverse everything, particularly if I were a left-handed person!
    B
  1. Replies: 23
    Last Post: 2nd December 06, 07:32 PM
  2. Pleat depth spacing preferences?
    By Eric T in forum Kilt Advice
    Last Post: 26th May 06, 04:30 PM
  3. pleat depth for 4" sett?
    By auld argonian in forum Professional Kiltmakers Hints and Tips
    Last Post: 26th October 05, 10:12 AM
  4. Pleat Depth
    By HeathBar in forum Kilt Advice
    Last Post: 28th May 05, 01:53 PM
  5. Sett Size ?
    By cavscout in forum Kilt Advice
    Last Post: 22nd April 05, 03:14 PM
