Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: Static cling?
    2nd October 07
    Static cling?
    Hey folks. So here's the problem. I have three kilts- two wool, one denim and a new SWK acrylic. I have never worn anything acrylic to my knowledge, so I really don't know much about them. I had to wash my new SWK last night, and when I put it on today, the static was incredible! It was sticking to my thighs! Any suggestions on how to get rid of the static?
    2nd October 07
    Also... is that profuse amount of static normal for this kind of kilt?
    18th December 06
    Burlington, Ontario, Canada
    You could try rubbing a dryer sheet on it or get a can of that Static guard. Might I suggest that in future that you not clean your kilts by rubbing vigorously with a cat. For one thing it ticks the cat off .
    The Grant.
    winstonwolf06 is offline This member has been inactive for more than 1 year
    19th September 07
    Oh, so DON'T rub vigorously with the cat... I knew I was doing something wrong
    My name is Winstonwolf, and I'm a Kiltaholic
    Yeti's Avatar
    Yeti is offline This member has been inactive for more than 1 year
    1st June 07
    Lexington, KY
    Don't use cats at all...dogs work much better. But only mutts...purebreds cause shrinkage.
    "If more of us valued food and cheer and song above hoarded gold, it would be a merrier world." - J.R.R. Tolkien
    21st May 07
    North Hollywood/Sun Valley, California
    A spray pak of Stat Gard or similar works wonders. Or rub with a wet toad during the waxing of the moon while turning widdershins....Oh, Sorry, that's for something else. Silly me!
    +Stan
    ...May ye be in Heaven half an hour afore the Divil e'en knows ye are dead.
    Victoria, BC, Canada
    Static Electricity is just what its name says, an electric charge that is just clinging to a surface because it has no where else to go.
    Simply ground it.
    Here's how.
    Find a copper pipe in your house,(There are a couple under your kitchen sink.) and wrap a length of copper wire around it.
    Then find the nearest Electrical outlet. (The one behind your stove with the big funny looking plug is a good one.)
    Dump a couple of cups of water on the floor and stand in it as you hold the copper wire in your teeth.
    Then with your kilt around yourself reach over and stick a knife into the plug.
    Voila!!! Your kilt will no longer cling to your legs.
    Disclamer ...... DO NOT REALLY DO THIS!!!!! It's a joke.
    The real way is to hold on to something without a charge like the proverbial door knob. Then run your other hand down the pleats of your kilt. Just like wiping the lint off. Then put that hand on the doorknob also. If this doesn't work right away try wiping your pleats with a very slightly damp cloth and then touch the cloth to the doorknob. This will ground the charge and let it dissipate.
    www.Freedomkilts.com
    2nd Laird of Lochaber
    11th February 06
    Upper Peninsula of Michigan
    If you are out somewhere and don't have the above items, dryer sheet, or a anti static spray, just splash some water from a sink faucet, wetting your hands, and splashing it on your legs or even the inside of the kilt. Dry weather causes static, so wetting it should diminish it.
    DALE.
    You don't have to be Scottish to be comfortable!
    2nd October 07
    I have 4 cats. I no choice in the cats being vogorously rubbed on my clothes. So barring getting rid of the cats, I think I'll try the doorknob idea. Thanks to people who were helpful, and kudos to the people who made me laugh. My cats would love you.
    emolas's Avatar
    emolas is offline Oop's it seems this member needs to update the email address in their profile.
    16th May 07
    Nashua, NH
    In the future, don't machine dry your kilt either. If you hang it to dry it won't develop nearly as much static.
    There are 10 kinds of people in the world...
    Those that understand binary, and those that don't.
