  #11
Old 12-03-2007, 01:14 PM
The Wizard of BC's Avatar
Owner/Kiltmaker
If I can expand on Barb's post. Her kilts are designed for a Traditional fit. This means that the top straps are cinched into the natural waist of the wearer. There is then the rise above the top strap. This rise is shaped to be wider than the waist. I know of no casual, contemporary, or MUG maker who incorporates true tapered rise into their kilts. This is one of the reasons that Barb and Kathy's kilts fit so perfectly. The place where the top strap is, is the narrowest part of the kilt. It tapers outward above and below from the straps.
A note on finding your Natural or True waist. Do not use your naval as a guide. Depending on your shape and weight your naval may not be in the same relative position as it is on someone else.
How you find your natural waist is around the back side, somewhere around your kidneys. Place your hands flat against your back with the fingers just touching at the spine. Then bend from side to side slightly. You will feel the place where your spine is bending. That is your true waist. If you have "Love Handles" Those pillows that sit just on top of your hip bones. Your waist is just above those. It is also just below the ribs at the sides and covering the short ribs.
Another way to find your true waist is to put on a t-shirt and then find a wide belt. fasten the belt around yourself just under the ribs. Then walk around for a while. Bend over and side to side a few times. Don't try to move the belt to where you think it should be, just let it find it's own natural place. If you have to, tighten the belt if it becomes loose. The place the belt settles into is your natural waist. And that is where the top strap of a Traditional kilt needs to fit. The flared Rise of the kilt will be above that.
__________________
www.Freedomkilts.com
2nd Laird of Lochaber
  #12
Old 12-03-2007, 01:35 PM
Bugbear's Avatar
That is very good to know. Thank you for explaining it in that way.
  #13
Old 12-03-2007, 01:41 PM
O'Neille's Avatar
Visit you kilt maker for a fitting whenever possible. They also get to see your body posture and shape and the finished product will fit even better than just the correct measurement.
__________________
X Marks Advertisers
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
USAK Buchannan Semi-Traditional pdcorlis Show us your pics 23 04-20-2006 09:10 PM
New USAK Semi-traditional Macman USA Kilts 9 01-07-2006 07:51 PM
My First USA Kilt, A Semi-Traditional Riverkilt USA Kilts 4 10-23-2005 10:28 PM
USA semi traditional bubba USA Kilts 6 06-01-2005 09:48 AM
X Marks Sponsors
