25th September 10, 07:54 PM
what's wrong with my pucker mocs?
I didn't use a pattern, just cut and stitched. any advice on making them look better? or something else I should be doing with them? hopefully these links work, I couldn't embed the images.
http://picasaweb.google.com/lh/photo...eat=directlink
26th September 10, 05:54 AM
 Originally Posted by scoutman77
One suggestion is to use softer leather, such as deer or elk. Cow is too stiff which is one reason why your puckers look like Christmas ribbon candy. Your "pattern" looks good though.
Remember too, that these are "disposable" shoes, designed to be worn for a few days and then replaced with a new pair. Looks were not a consideration.
1745 Appin Stewart Regiment
US Marine (1970-1999)
Clan Elliot, Donald, Gunn, Morrison, and Leatherneck
26th September 10, 07:02 AM
I'll second that...
Agree with Sir William's advice about the type of leather. I've never made a pair of mocs like this for highland wear...but I've made several pair of eastern woodland pucker toe, center seam mocassins in my day. Simply from observation I'd suggest:- More supple leather (Moose and deer are top choice...elk works but has some sort of grain difference that makes it inferior if memory serves).
- Make the distance between your lacing holes closer together to give smaller puckers and more of them
- I'd make it a tad bit wider to extend up the ankle a bit higher...my personal opinion there...not sure that it reflects any historical accuracy
- Finally, Not sure if this was done by highlanders, but I like to wrap the thong around my foot at the instep and then up around the ankle...it keeps the moc more securely attached to your foot and reduces stretching, slipping, and sliding (especially as your leather gets wet/damp and likes to stretch).
26th September 10, 05:26 PM
I changed them a bit in the advice given, (except the leather, I have alot of cow leather, but no deer or elk). I laced them across the top a little way also. what would a person wear under these? knit socks? bag socks? with flashes? nothing? maybe some fur lining?
thanks
rob
26th September 10, 05:53 PM
Mind you that my "pucker mocs" are only used for ren-faire, I wear them with nothing most of the time. However, as far as what's "wrong" with them, I'd say you didn't allot enough for the toes. Maybe they didn't go up the instep enough? That's just my opinion, take it with a grain of salt (and a shot of tequila).
Part Irish, English, German and Cherokee.
All American.
26th September 10, 07:54 PM
Some changes, I will use mine for renfest as well. also probably wear them to a Halloween party.
26th September 10, 08:06 PM
That looks much better. As Sir William said, they are meant to be a somewhat "disposable" shoe, but mine have lasted me quite a while now. At least 5 or 6 weekends worth of ren-faire straw/gravel pathways for me. The lacing up the instep definitely gives it a more tailored/tight/finished look, IMHO.
All American.
26th September 10, 08:09 PM
Yes, I needed to pull them together at the instep. they fit alot better that way too!
2nd October 10, 08:11 AM
Those look almost exactly like a pair I made a fews years ago... save that yours are probably a bit nicer. I think they look good, and so long as they're comfortable, I think you should pat yourself on the back for a job well done.
And if you have the time, materials, and inclination, you should wear them with cut and sewn (on the bias) tartan hose and tie-on garters.
 Originally Posted by piperdbh
By Electrickilt in forum Tech Questions
Last Post: 19th August 09, 02:51 PM
By Darkislander in forum General Kilt Talk
Last Post: 11th December 08, 08:08 AM
By TheKiltedCoder in forum General Kilt Talk
Last Post: 8th June 08, 09:05 PM
By arrogcow in forum General Kilt Talk
Last Post: 27th October 05, 10:09 AM
Last Post: 3rd October 05, 08:33 PM
