Page 7 of 7 FirstFirst ... 567
Results 61 to 63 of 63
  1. #61
    5th November 08
    Marion, NC
    Quote Originally Posted by Mr.Charles Anthony View Post
    If you are at least semi-skilled in sewing, I can provide the Pattern source, to make your own.
    Provide away!
    --dbh
  2. #62
    4th June 08
    Maine
    Re: Does anyone make this style coatee?
    Tobas!
    Pardon the delay in a reply- I do not view a computer every day; But;
    to answer the Good Question.
    It is a common workmans coat, by which I mean the coat you would toss on to feed the horse in the morning, cut firewood &tc. It is not a coat for Sunday-go-to-meeting. That would be the coat you would see in an Image of, say, Benj.Franklin. I arrive at the conclusion by 1st reading & then checking the Sources listed in the Pattern I purchased to make the coat for myself, the 1st one i blanket wool, to do the chores around my own farm(& I like more than a Walmart workcoat).
    As to View that it has been 'tricked up' I infere,1) that I did the same when I made the coat in white canvass. 2) A long association with 18th Century tailoring tells me the same. 3) If you were to look thru a flock of images of workmans coats, you wil find all sorts of variations on the theme.
    Let me use the coat you are use to seeing on a Founding Father of your choice, as an ensample. The coat could be made of plain wool, 4 body panels, and 2, two part sleeves. That is the basic coat. To make it different, the cuffs can be false, deep, or shallow, the buttons can be plain or fancy. Or the Basic Coat can be plain silk, patterned silk, white linnen &tc. The Button Holes can be worked, taped, laced or false. The lining can be plain, fancy, half lined, good facings with common linnen linings not seen. The entire list is Very Long; but the Point, I hope, is clear. You can vary any coat to suit the occasion. In the Occasion of the Pictured Coat, which started the thread, e have the Era of "All things Highland" craze. So it is no small surmize that the coat would be altered to suit the 'fashion of the times'. Look also at other "Highland Coats" of the era, and many, if not all, are variants on the styles of the time, just as the Prince Charley coat is simply a tailcoat, sans tails & with a few 'tidbits' added. And the tailcoat goes back to circa 1800. Does that prove helpful? If nay, let me know.
    With thanks for your interest, I remain
    Mr.C.Anthony
    Historical Tailor
  3. #63
    19th May 08
    San Diego CA
    See this thread
    related thread
    Courtesy Mr. Charles Anthony
    And a link to the page he mentions
    http://www.kannikskorner.com/patmen.htm
  1. ARRGH! Make it stop! Make it stop!
    By CDNSushi in forum Miscellaneous Forum
    Last Post: 17th April 09, 12:07 PM
  2. Prince Charlie Coatee
    By JSFMACLJR in forum How to Accessorize your Kilt
    Last Post: 2nd March 09, 06:53 PM
  3. Make your own skunk (or make me one...)
    By attworth in forum DIY Showroom
    Last Post: 6th August 08, 06:36 AM
  4. Replies: 59
    Last Post: 4th September 07, 09:27 AM
  5. Bonnie Prince Charlie Coatee & Vest
    By dejudicibus in forum How to Accessorize your Kilt
    Last Post: 24th December 05, 02:48 AM
