18th June 11, 06:59 AM
#11
Pleating to the stripe was also done for economic reasons:
1) Even in the higher yardage styles preferred by the military it uses slightly less fabric. If the kilt is being made from a tartan where a line repeats itself more than once even less fabric will be used. Black Watch is a good example. It's typically pleated to the stripe using only half of the sett.
2) Future alterations: Pleating to the stripe means there is no centre stripe in the back. Buckles can easily be moved without worrying about the kilt looking off-centre from the rear.
John Hart
Owner/Kiltmaker - Keltoi
10% Discount for XMTS Members (Kilts & Plaids)
18th June 11, 01:54 PM
#12
I never thought of #2....I suppose I will just have to remain the same general size and proportions But seriously, something to keep in mind.
18th June 11, 07:51 PM
#13
Yes indeed! And it's another reason NOT to have belt loops on the back.
I think it's one reason pipe bands so often go with pleating to the line, as in pipe bands kilts are rarely made for the specific people and kilts have to have buckles moved often.
19th June 11, 04:20 AM
#14
Making future alterations easier is certainly true. You have no "center stripe" in the rear to worry about, as John points out. Also, it makes it easier if you have to cut out any pleats to make the kilt smaller. A few times I've had to remove several inches of pleats to size kilts down, and the fact that they were pleated to stripe meant you could never tell by looking at the kilt. Had these kilts been pleated to sett you would notice a significant portion of the sett pattern missing.
However, I would not say it is necessarily true that pleating to the stripe uses any less cloth than pleating to the sett. Let's say the set size is 7". If you are pleating to the stripe, you are going from one stripe in the tartan to the next occurrence of that stripe and so the pleat is going to be 7" over. If you are pleating to the sett and your pleats are 1/2" wide, then your next pleat would either be 7.5" over or 6.5" over to get to the point in the pattern you need. So pleating to the sett may use slightly more cloth, or it may use slightly less.
Effectively, it's very little difference. If you are ordering an 8 yard kilt, your kilt maker will request 4 yards double width cloth from the mill, regardless of whether your kilt is being made pleated to stripe or sett.
20th June 11, 08:18 AM
#15
A very informative thread with good photos to illustrate both pleating styles. Matt looking very dapper and well turned out as usual.
Santa Wally
Charter member of Clan Claus Society, Clan Wallace Society
C.W. Howard Santa School Alumni
Fraternal Order of Real Bearded Santas
20th June 11, 01:02 PM
#16
6 Yard Box Pleat
Is it the number of pleats that increased your pictured box pleat to 6 yards?
What is it that required the additional 2 yards? BTW, that tartan looks grand box pleated which tartan is that? Thanks
20th June 11, 01:11 PM
#17
Well, the tartan has an unusually large repeat, I think it was about 10". If I did a four yard box pleated kilt, that would have resulted in very wide pleats, about 3.25", which I did not want. So the extra two yards allowed me to have more, narrower pleats.
By xman in forum Kilt Advice
Last Post: 3rd April 10, 01:46 PM
By jhockin in forum DIY Showroom
Last Post: 28th November 09, 05:13 AM
By g koch in forum General Kilt Talk
Last Post: 29th November 08, 09:47 AM
By canawler in forum General Kilt Talk
Last Post: 13th April 07, 09:56 PM
By MacWage in forum The Tartan Place
Last Post: 4th July 06, 08:35 AM
