05-20-2010, 07:56 AM
I purchased the belt over the winter as i was shrinking out of some belts mainly for jeans or shorts, but was thinking it might look pretty nice in the casual Kilt dept, what's the consensus? |
05-20-2010, 08:06 AM
|  | | | Join Date: Sep 2009 Location: Hong Kong (by way of Toronto, Canada)
| | Quote:
Originally Posted by oldscubaguy I have an adjustable kilt belt from Scotweb and am having problems.
Because of the extra leather on one side the belt does not lie right and the buckle angles. Solutions? | This sounds like a traditional kilt belt (cavscout's) second example. As he mentioned, keepers might help. Also, if the belt is stiff and new, it might need to be worked in a bit so that it folds over more easily.
__________________
- An t'arm breac dearg
05-20-2010, 08:15 AM
| | Quote:
Because of the extra leather on one side the belt does not lie right and the buckle angles. Solutions? | I've had similar trouble with the traditional, wide kilt belt. The extra leather makes it thicker on one side for an awkward look and feel. I tried adjusting it to the proper size, removed the buckle and then put something heavy (a treadmill) on the loop where the buckle goes to try to flatten it out so the buckle doesn't angle so much. I met with middling success.
Sorry for the threadjack. Try searching for "kilt belts" for more info!
__________________ Touch not the cat bot a glove. |
05-20-2010, 08:35 AM
|  | Oop's it seems this email address is no longer valid | | Join Date: May 2010 Location: Los Angeles
| | Quote:
Originally Posted by cavscout Do you have any pics of the belt you are having a problem with so we can see the type of belt you are working with and what the issue is?
Casual belts are more like this
and "Traditional" would be more along these lines
Is the extra leather flapping around? If so a keeper to hold it in place should do the trick. Give us more detail and I'm sure we can help. | The belt I have has velcro on the inside for adjustability but creates a double belt thickness on one side. Here is the link to the belt I have: http://www.scotweb.co.uk/sr_wscot_belt_adjustable_velco |
05-20-2010, 08:56 AM
| | Quote:
Originally Posted by sanddog28 I purchased the belt over the winter as i was shrinking out of some belts mainly for jeans or shorts, but was thinking it might look pretty nice in the casual Kilt dept, what's the consensus?  | That's a nice looking belt, how wide is it?
I've seen 1.5" (regular pants size) belts look OK on a casual kilt that sits at the pants waist but I think a wider belt looks better...
__________________
05-20-2010, 09:22 AM
| | Quote:
Originally Posted by CMcG That's a nice looking belt, how wide is it?
I've seen 1.5" (regular pants size) belts look OK on a casual kilt that sits at the pants waist but I think a wider belt looks better... | I had to actually go measure it LOL, I knew it was bigger than standard as it doesnt fit in some of the belt loops I have. Turns out its 1 3/4".
05-20-2010, 09:42 AM
| | Quote:
Originally Posted by sanddog28 I had to actually go measure it LOL, I knew it was bigger than standard as it doesnt fit in some of the belt loops I have. Turns out its 1 3/4". | That's the width of the garrison belt sold by Sportkilt. Should do the trick!
__________________
05-20-2010, 10:33 AM
| | Quote:
Originally Posted by CMcG That's the width of the garrison belt sold by Sportkilt. Should do the trick! | Too bad they're only available in black. I've got a new kilt showing up at the door today and need a brown casual belt of that style to go with it.
05-20-2010, 11:03 AM
| | Quote:
Originally Posted by oldscubaguy | Yeah, the type of leather in that belt is very stiff and rigid to begin with and then the continuous velcro restricts the folding as well. You can try simply rubbing a liberal amount of mink oil into the belt to soften it up and make it more pliable. Flexing and crushing it over and over will break down the fibers a bit also. Getting the keepers that came with it pushed up tight to the buckle should help to pinch and hold the fold also.
05-20-2010, 01:21 PM
| | Quote:
Originally Posted by NewEnglander Too bad they're only available in black. I've got a new kilt showing up at the door today and need a brown casual belt of that style to go with it. | You might want to try the Lucky Jeans site then or if you have a store around you, the three belts i have picked up on clearance from there are all the same width as the one I posted. Might be that their belt loops on their jeans are that size as a standard, so all their belts are a bit wider.
Posting Rules
