Results 1 to 8 of 8
    15th April 09
    Whistler, Bc
    Compression Hose - Kilt Hose
    Does anyone make a compression hose that I can wear with a kilt?
    30th June 06
    Lotusland, Canada
    I occasionally have to wear prescription compression hose. I just wear them under my kilt hose.
    Gentleman of Substance
    14th January 08
    Goshen, KY
    Like Mikey said. Knee highs should be fine with proper kilt hose. If you need longer compression hose go for skin tone and don't worry about hiding your knees-----wear teh kilt and hose anyway. your health far outweighs a little bit of spandex showing between the top of your hose and the bottom of your kilt, and your mental health will definitely be aided also by the freedom of wearing the kilt.
    19th March 09
    Astatula Florida
    I agree with Forrester 100%..........Health consideration over fashion.
    5th November 08
    Marion, NC
    I have no experience with compression hose, but would well-fitting hand-knit hose work? They can be made to exactly fit your leg, unlike most machine-made hose. There are several of us here who make kilt hose and other socks, if you want to explore that option.
    --dbh
    28th August 08
    Peoria, Arizona
    Just be careful- the tops when turned down can create a kind of tourniquet and impede venous return. I agree with the others- wear under kilt hose. Now having said that- there could be a whole industry out there of tartan ted hose for the craft minded that wishes to pick up on it.
    Todd M.
    5th November 08
    Marion, NC
    Sionnach,
    With handmade hose, the tops/cuffs don't have to be so tight. They can be bigger that the leg of the hose, which would eliminate the tourniquet effect. I prefer to make hose and socks that hold themselves up with ribbing rather than depend on flashes or garters to do all the work. It's also possible to make hose with no cuff, and tie them (loosely) with garter ties, or no ties at all. I suppose it depends on how you plan to wear them, and how traditional or formal you want to dress.
    --dbh
    14th January 08
    Goshen, KY
    Careful with ahything that might cause the tourniquet effect just below the knee. Compression hose are specifically designed to provide progressively decreasing compression of the soft tissues, and thereby the blood filled veins, of the legs, withthe highest compression at the foot and ankle and gradual gradation as you ascend the leg to wherever the hose stop---knee or thigh most commonly. The idea is to help push the blood from the lower legs north toward the heart and keep it from stagnating in the lower legs, causing varicose veins and blood clots, which could be fatal if they break loose and go into the heart and lungs (pulmonary embolus). Putting a garter tie at the knee defeats the purpose by causing that tourniquet effect. Wear the compression stockings, then your kilt hose over top without a tight turnover or garter at the top, and the texture of the compression hose should help hold up your stockings if they at least fit reasonably well.
    NO, I didn't stay at a Holiday Inn Express last night---I really am a doctor.
  1. Tartan hose vs plain hose
    By Kilted kiwi in forum General Kilt Talk
    Last Post: 10th March 09, 01:23 PM
  2. Tartan Hose or Solid Color Hose?
    By dtandthekilt in forum General Kilt Talk
    Last Post: 16th February 09, 09:49 AM
  3. DIY Kilt Hose
    By BozemanboB in forum DIY Showroom
    Last Post: 24th September 08, 06:45 PM
  4. Summer Hose Look, SportKilt $6 Kilt Hose Pushed Down
    Last Post: 20th June 06, 06:33 PM
  5. Kilt Hose
    By Plastic Paddy in forum How to Accessorize your Kilt
    Last Post: 15th March 04, 08:43 AM
