16th August 08, 09:08 AM
Folding Knife as a Sgian Dubh?
I realized this morning that I own a beautiful folding knife. Was made to be worn in a belt pouch and I keep it there so hardly ever see it. The handle is inlaid with turquoise and other stones. Was made by a Navajo craftsman. I bought it at a roadside booth out on the rez about five years ago.
Got to wondering if I could use it as a sgian dubh by opening it up and sticking the blade in a sheath. After all, the purpose of the sgian dubh these days is decorative beauty.
Playing with it I found it looks nice save the part that has the little push thingie to refold the blade. Don't think anyone would notice that.
But because the handle is so thick and inlaid with stone it really seems top heavy. Gonna play around with it some more.
Wondering if anyone else has converted one of their folding knives for sgian dubh use??
Ron
PhotoBucket Album
16th August 08, 11:48 AM
I've never thought about it Ron, but I think my 110 Buck knife should stay as a folder not a sgian dubh. This way I get to collect more knives.
16th August 08, 03:38 PM
Aye, buy another nice one and leave it a folder.
A man can never have too many knives anyway.
If you really wanted to do that, the best way would be to split the knife by dis-assembly, and use one half of the folder handle (likely the RH side), and make a spacer/blank to take up the space, of just use it on a new straight blade, and leave the back flat. But really, it is more work than it is worth.
I do frequently carry a folder instead of a sgian dubh in my sock, usually one with a pocket clip, tucked in between the aprons of the kilt at the top, with the clip on the outside of the outer apron, but under the belt.
16th August 08, 04:06 PM
Why not just tuck the folder into your sock? Er... folded, of course.
16th August 08, 09:14 PM
Actually I'd like to see someone make a folding sgian dubh anyway, so as to eliminate the annoyance of dealing with the sheath when taking the knife out of the sock.
"...the Code is more what you'd call 'guidelines' than actual rules."
Captain Hector Barbossa
16th August 08, 10:22 PM
The following is anticipating using a folder about the same 4" handle length as a traditional sgian dubh. If you went with a longer folder it would be possible to mold a sheath to hold the folder about 1/2 way up the handle leaving about 1/2 the knife above th hose to grip. A 4" handle though would only leave at most 2" visible and available for gripping above the hose so your looking at a folder at least about 5" long folded.
This has been a thought I've played with for quite a while and I always come back to the same outcome, it's not practically possible to wear a short folder in the sock and have it serve as a sgian dubh without sacrificing the decorative value, easy draw/use functionality or the secure stowage.
The sgian dubh is mostly a decorative knife worn usually for appearances so the handle needs to be long enough to stick out of the sock to be seen. To anchor a knife with a handle that long into your sock, you will need something running down into the sock at least the length of the handle (typically the blade in a sheath). A folding knife would eliminate the anchoring portion in the sock and increase the weight in the handle above the cuff of the sock making the knife extremely top heavy and prone to wiggling free of the sock while walking.
I carry the "Officer" sgian dubh by Gaelic Themes which is sort of a folder. The blade is fixed but there is a cork screw and bottle opener/screw driver folded into the handle. It's a very top heavy sgian compared to most.
The best solution I've found for anchoring a top heavy knife into a sock with minimal anchorage in the sock is to replace the stock sheath (far left) with a molded sheath (middle).
The extra height on the sheath wraps around the bottom of the handle anchoring it into the sock very securely.
The molded opening also protects the expensive kilt hose from being sliced up by providing a constant opening to easily unsheath or resheath the knife.
The sheath rides right at the top of the cuff so it's very low profile.
So far I've not come up with a design for a folder that can be worn in the sock, stay secure in the sock when walking, be decorative / visible and not be 3 times as long.
Even a sheath that gripped the folder 1/4 to 1/3 of the way up the knife might still have problems with wiggling loose without a bit of blade running further down.
16th August 08, 10:30 PM
Here's another thread with a sheath that was made for a large, heavy hunting knife
http://www.xmarksthescot.com/forum/s...7&postcount=29
17th August 08, 08:41 AM
Wow! is this a great board or what!!?? Thanks all.
Hey MacDougall, welcome back. I did try it folded but as Cav Scout says its top heavy and I sure don't wanna lose this baby.
Maybe I should find out where the blank blades they make sgian dubhs from come from, then take them around to Native artists and have them do up the handles....
Ron
PhotoBucket Album
17th August 08, 08:47 AM
17th August 08, 08:55 AM
Thanks cuz, off to do that.
PhotoBucket Album
By RedBeard in forum DIY Showroom
Last Post: 21st May 08, 05:58 PM
By freddie in forum The Cooling Off Corner
Last Post: 18th December 06, 08:12 AM
By Galant in forum How to Accessorize your Kilt
Last Post: 20th February 05, 08:13 AM
