Results 1 to 10 of 24
    3rd February 05
    Virginia
    Help with building a skunk fur sporran
    I am getting married in August and I am lacking a more formal sporran. The one I have is a semi dress brown rabbit front. I think something in black would look better with the Macgregor kilt I will be wearing.
    I have aquired a full skunk pelt. I am seriously considering making a sporan out of this pelt. It has character and would mean a lot to the person that gave me the pelt.
    I have a general idea for the pattern and access to leather at a local shop for the gusset sides and back panel.
    Does anyone have any advice on working with fur pelts for sporran making? I have searched here and google. I see a lot on bare leather but little on fur. I think that building it inside out would help hide the stitches on the fur side.
    The mask was not removed carefully enough to use for a "full mask". The tail is in great shape.
    I do not have a cantel and I am not sure if I even want one on it. That leads me to building a flap out of part of the pelt.
    I have an idea of putting the fur on the flap and making the flap the main part of the sporran. Under the flap would be plain leather. You would only see that area if the flap was open.
    I will try to post a photo of the pelt so you can see what I have to work with.
    My photos can be found at http://www.docwalkersphotography.com
    29th January 06
    Asheville, NC
    My suggestions would be these.
    1. Don't use the tail on the flap. It would end up looking a bit more penile than you'd want at a wedding.
    2. You'll probably have to work inside out then reverse it, as you stated. Be certain that neither the gusset nor the back are too rigid, since you definitely don't want to wet the pelt (wetting stiff leather is the only way to do the reversal)
    3rd February 05
    Virginia
    No, I was not going to use the tail for the flap... :-) That would not look appropriate at all. I might make a key chain out of it.
    27th March 06
    Ferintosh, Dumfries, Scotland
    use this threid as a visual reference....
    http://www.xmarksthescot.com/forum/s...ad.php?t=17878
    Bae Cannie! ...many fur sporrans turn oot ooglie an luekin like roadkill...
    ya dinnae want tae hae roadkill tied roon yur waist.... :rolleyes:
    ai suggest buyin' a gorgeous enameled sporran instead....
    3rd February 05
    Virginia
    I wish that mine had a decent mask to work with. As for road kill.... would a good highlander have used roadkill? That is if they had cars killing the critters? Its would be a shame to let a good pelt go to waste. Plus the tire tread gives it more texture :-)
    5th September 05
    Chicago
    badgers? we don't need no steenking badgers....
    ...once again, I'll refer you guys to that leather company that has a suprising range of pelts available:
    leather unlimited
    http://leatherunltd.com/leather/skins/skins.html
    Skunk is further down on the page.
    I can't vouch that the masks are in sporran-perfect shape but you can probably contact them and asks...they seem very customer oriented.
    Best
    AA
    5th January 06
    Manteca, California
    Quote Originally Posted by usndoc
    The pelts of small furbearing mammals make wonderful sporrans. I've made several and will make many more from my collection of pelts (if I quit making kilts from my collection of fabrics and tartans.) Do not discount the tail. Both the mask AND the tail are in use here on my favorite homemade sporran. Because the tail is off-center, there is no risk of it being mistaken for something else very large and hairy, but it does have a nice "swing" to it that complements the swing of the pleats behind.
    Referring to the tail ONLY - here is a my homemade badger sporran with the tail on the flap. In truth, I only put it there as a placeholder for the full mask - if or when I get it finished.
    Both of these are very large, fully usable sporrans. They were constructed with a plain fabric front panel. The mouth of the sporran is reinforced with a circle of stiff leather belt. The main piece of fur is cut large and handstitched to the belt and somewhere on the gusset toward the back panel, and the stitching is not nearly as noticeable as you imagine. Stuff the sporran to fullness with newspaper beforehand. The edges of the fur have to be gently "pleated" around the curves. Extra pieces of fur are glued/stitched on each side of the flap to flank the mask or tail or whatever (or do the whole flap in fur.) I pass on adding feet or tassels.
    These sporrans are obviously rustic, but have a certain classiness to them. Mr. Skunk nicely complements any black and white outfit.
    Kids will love your fur sporran - but beware of women who try to pet your sporran while you're wearing it!
    Lady From Hell vs Neighbor From Hell @ http://way2noisy.blogspot.com
    5th January 06
    Manteca, California
    As for road kill.... would a good highlander have used roadkill? ... Its would be a shame to let a good pelt go to waste.
    I have had two good experiences with FRESH!!! roadkill, a year apart. Two fine specimens of local gray fox, both skinned immediately, salted, and rolled. One I oil tanned using a mail order tanning kit; the other went to a local tannery and was dry (or garment) tanned.
    If the kill is not fresh (hours, or a very cold overnight), decomposition destroys the hair follicles and the fur pulls out. Most tanneries will not take walk-in trade for this reason, or will make you sign a waiver regarding damage during the tanning process.
    Highlanders wore whatever they could, ate whatever they could, and used sticks and really heavy stones to amuse themselves in athletics. I'd bet they used whatever (and however it was presented) to fabricate articles of high utilitarian value.
    20th December 04
    Charlottetown, PEI
    tartan?
    wow..that's a striking pattern on the kilt your wearing in the middle pic. Looks great with all your black gear. Who's the maker of that kilt, if you don't mind me asking?
    Inside me is a thin woman screaming to get out. But I can usually shut the b*tch up with chocolate!
    3rd February 05
    Virginia
    Here is a link to photos of the pelt I was given.
    http://www.docwalkersphotography.com/gallery/1512778
    Hopefully I can make something of this. I want to go by the leather shop soon to find the other pieces.
