03-08-2010, 07:52 AM
|  | | | Join Date: Sep 2009 Location: Hong Kong (by way of Toronto, Canada)
| | Quote:
Originally Posted by auld argonian ...and I've heard such horror stories about members of the US armed services soaking, shaving and flambe-ing their berets...obviously they can't hold a candle to this absolutely medieval treatment of a poor, innocent piece of headgear. What is this? The Inquisition?  | That description of Jock's method is hilarious!
__________________
- An t'arm breac dearg
03-08-2010, 09:12 AM
| | Quote:
Originally Posted by KFCarter Excellent...Great help, Jock!
I've got a bonnet that's too "new" and a bit too big. Now, to find a stream clean enough for the purpose! | Actually you can use the bath, sink or just a bowl. I just happen to have a burn handy and it stops the usual war cry of, "Have you finished yet? I need that now!" type comments. Be careful with the shrinking process and if it is only a wee bit, then use cold water and time and don't be tempted to rush things.
If you have more than a wee bit to go and remember, there is only so much the thing will shrink, then after the cold water and time method has been tried then use WARM water, NOT HOT water and that might do the trick. Be warned, if you use hot water, the whole thing could shrink in all directions and your bonnet will go out of shape permanently.Failing all that; you should have an inverted "V" gap in your bonnet hidden by the bow. Yes? To close up your bonnet by, perhaps at best an inch, sew on some elastic tape on the inside of the bonnet on one side of the "V", close the "V" and sew the other side of the elastic to the other side of the "V" allowing the gap to expand when placed on the head. Failing all that and if all those suggestions don't work------- buy a smaller bonnet!
03-08-2010, 10:15 AM
|  | | | Join Date: Feb 2008 Location: Seattle, WA: N 47° 40' 50.109";W 122° 17' 14.7726"
Great pics of this time-tested method of bonnet-fitting!
__________________
The Barry
03-08-2010, 10:20 AM
|  | | | Join Date: May 2006 Location: Far NW Corner of Washington State, USA (48° 45' 51.5808" N / -122° 30' 36.6228" W)
| | | Jock, when all's said & done would it be possible for a side-by-side comparison of the old bonnet & the new? I for one am curious.
__________________ T. E. ("TERRY") HOLMES proud descendant of the McReynolds / MacRanalds of Ulster & Keppoch. "Ah, here comes the Bold Highlander. No arse in his breeks but too proud to tug his forelock..." Rob Roy (1995) |
03-08-2010, 10:26 AM
Jock you have perfectly illustrated what I've advocated for a long time, i.e., adjust your bonnet before wearing it by soaking and drying and fitting! I always give mine a soaking in the sink since I don't have a bern nearby.
The best advice you gave is "patience." Don't rush the process. To make a bonnet look googd and well-worn, you really do have to spend a few days on it. But the end product will be worth the time it takes.
Can't wait to see it when you're all done. Thanks for the photos. That is one very fine bonnet.
__________________
Jim Killman
03-08-2010, 10:46 AM
| | Quote:
Originally Posted by BoldHighlander Jock, when all's said & done would it be possible for a side-by-side comparison of the old bonnet & the new? I for one am curious. | Will do. Although apart from being newer and less stained you do need to remember that this was a custom build and the diameter across the top was, I think made at my request, slightly smaller than the commercial bonnets. Perhaps Chris (Redshanks) will chip in with whether the "custom" option is available to all and not just this lucky chap!
03-08-2010, 11:29 AM
The Mackie produced Balmoral Bonnet comes in various headsizes, measurement being set buy the headband, but the actual bonnet part comes in a standard size, the options available are diced or plain headband, ribbons tie or loose.
Because I specifically went to Mackie's with a view to ensuring the best possible match to Jock's old bonnet, it was evident that the bonnet size had changed over the past 30 odd years, and they offered to make one up specially, so Jock's new bonnet is very bespoke.
But I am certain that as Mackie's hand produce every bonnet anything is possible, I can only ask.
03-08-2010, 11:51 AM
Jock, thanks for the informative "article" on breaking in a new bonnet. I do hope that you will share a photo or two of the bonnet being worn so that we might all see the end result of your "loving" shaping of it.
__________________
Member Order of the Dandelion
03-08-2010, 11:59 AM
What a handsome balmoral! Thanks for sharing this information. |
03-08-2010, 12:09 PM
I like the knitted dicing and the felted top. I am interested in learning how they've made this. I like to learn new things even when I never intend on doing this myself (can you imagine the time???). My Mackie didn't come with the ability to adjust the back at all. Solid all the way around. I wold have liked that option greatly. It would have made tying the bow easier too.
I like the color. I am tired of seeing blue and black.
Posting Rules
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | |
Similar Threads | | Thread | Thread Starter | Forum | Replies | Last Post | | Balmoral Bow Help | ChattanCat | DIY Showroom | 10 | 11-08-2008 09:28 AM | | balmoral | haxtonhouse | How to Accessorize your Kilt | 16 | 01-12-2008 09:03 PM | | balmoral | mcvarmit | General Kilt Talk | 58 | 06-26-2007 08:15 PM | | 8yd Balmoral vs. 8yd Top Value | cavscout | Kilt Advice | 8 | 03-20-2006 07:26 AM | | |
