29th September 07, 11:05 AM
Kilt ties
I've never worn a tie with a kilt because when worn up above my navel the tie will hng over my kilt by several inches. What is the standard length of a kilt tie? Has any one ever modified a tie to suit?
The Grant.
29th September 07, 12:04 PM
The tip of the front bit of your tie should be no lower than the top of your belt.If you are wearing a waistcoat the tie must not poke out from the bottom of your waistcoat.If you find your tie is too long,just re-tie the tie so the front bit is correct and just tuck the rest inside your shirt.
29th September 07, 12:24 PM
Are there no specific kilt cut ties?
The Grant.
29th September 07, 12:38 PM
Grant,
What works for me is to tie the tie so that front part of the tie is the proper length just above my belt (I always use a full windsor knot). The back part of the tie will be longer the front know so I simply fold it up along itself and then connect the three layers of material with a tie tack or a tie clip. In my experience the tie clip works better.
Reason: Typo
29th September 07, 12:44 PM
Not that I know of.The other thing to avoid are wide ties,they will make you look like Al Capone! Just a thought, Loch Carron make very nice solid colour ties that are nicely proportioned and I have no doubts that they would be be too long.
29th September 07, 01:35 PM
And, take great care if buying a tartan tie from a highland games vendor. Some of them are made very short. Be sure to know the length you need for your body. Otherwise, about all they're good for is peeking out the top of a sweater.
Ron
PhotoBucket Album
29th September 07, 01:37 PM
Ron
This may be the ticket as I find regular ties just too long, even for Saxon clothing.
The Grant.
29th September 07, 02:01 PM
Ties have different tapers, wide or narrow as individual preference or fashion dictates. I presume most well-cut ties are designed to end at the belt line for trousers worn in the usual manner. Since kilts often rise higher, some adjustment is necessary. In the case of a tie that is too long, perhaps a bulkier knot will shorten the front part enough. The thickness of the material also plays a part. I found, when I used to wear ties, that some of them simply could not be tied properly with any knot because the thickness and taper were incompatible. Others tied perfectly every time. It takes a little experimentation or in stubborn cases you just have to get a different tie.
29th September 07, 05:23 PM
There is no need to shorten a regular tie to make it work with kilt!
What you need to do is learn to tie the knot using more material.
Go here: http://www.tie-a-tie.net/windsor.html and learn how to tie a windsor!
That will use up enough length of a standard tie to make it work with a kilt!
29th September 07, 05:42 PM
That is what I have always done, Jock. I have also tied my ties in a Windsor knot for as long as I can remember (but not quite back to when they were first invented!!), which uses up a little more tie than some other knots. On the other hand, I am/was (!) fairly tall and that must help.
No. of Kilts: 102. "Title": Lord Hamish Bicknell, Laird of Lochaber / Life Member: The Scottish Tartans Authority / Life Member: The Royal Scottish Country Dance Society / Member: The Ardbeg Committee / My NEW Photo Album: Sadly, and with great regret, it seems my extensive and comprehensive album may now have been lost forever!/
By cacunn in forum DIY Showroom
Last Post: 25th September 07, 04:58 AM
By campbell in forum Kilt Advice
Last Post: 14th September 07, 09:12 AM
By Tattoo Bradley in forum Miscellaneous Forum
Last Post: 10th September 06, 10:38 AM
By Southern Breeze in forum How to Accessorize your Kilt
Last Post: 13th March 06, 12:07 AM
By David in Maryland in forum How to Accessorize your Kilt
Last Post: 4th March 04, 06:19 PM
