Contemporarily made Kilts and How to Wear Them. This forum sub-section is for those interested in learning about and discussing Contemporarily made kilts and to discuss and see examples of how kilts can be worn to emulate a contemporary style or fashion.
  #71
Old 06-07-2010, 12:06 PM
Quote:
Originally Posted by Drac View Post
I said yes but doesn't matter since there's a hole in the bottom. You should have seen the stunned looks I got.
Jim
I gotta remember that answer .
Rather than the two pouches you attached, how bout seeing if the Nightstalker sporran could be made from similar material? Or "Nightstalker" like, anyway? I guess I would opine that there's a certain shape that says "sporran", and since you're absolutely right that the style and material of those pouches would work great, take it one step further and round 'em out like a standard sporran.
If those pouches are inexpensive, maybe a little exploratory work with some scissors, needle and thread? The one on the left, if the corners were chamfered rather than rounded, would look pretty good IMHO.
FWIW, if you pull a few links from that chain, the sporran will sit at a better height without any need to change the strap. I attacked the frog end of my own chain (it came about as long as yours) with a pair of dikes and some pliers, so any "accidents" of my attention would be hidden. If those links are anything like the ones on mine, they're not actually welded, the plating (if any) is just over the seam...so I didn't actually even have to cut anything, just spread a couple loops and then bent the loops on the frog back together after "adjusting".
Yeah, I should swap the chain to something less potentially damaging, I know...
-Sean
  #72
Old 06-07-2010, 02:16 PM
Drac's Avatar
It's actually only one bag just back and front views. In this cases I won't need a chain as this pouch is made to got on the "rigger" belt I am wearing.
Jim
__________________
I cook with a flair for the dramatic,
and depraved indifference to calories
  #73
Old 06-18-2010, 07:15 AM
i like a ghillie shirt as a casual top to my kilt wear
something else i like is a lose white shirt and blue waistcoat over the top, doesn't look to dressy and is really comfy, wish i had a pic of that, next time i wear that i'll take one
X Marks Advertisers
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
New 11 oz. Ross Red Modern Kilt gairloch Show us your pics 10 01-20-2008 07:45 AM
Modern Douglas PV Kilt Riverkilt Show us your pics 3 10-09-2007 01:54 PM
Best modern kilt for use with sporran Cinnabar Contemporarily made Kilts and How to Wear Them. 10 05-30-2006 05:07 PM
Modern Kilt Book? switchblade5984 General Kilt Talk 16 04-14-2006 11:38 PM
Which modern kilt next? Davidweed Kilt Advice 9 09-23-2004 01:44 PM
X Marks Sponsors
