Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
    30th November 04
    Deansboro, NY
    Hi Tómmes,
    That's wonderful that he was willing to send you pics. I think I'd stick by my recommendations from my previous post. I think he needs a goodly amount of taper in the apron, and the pleats taper will pull it in to the small of his back enough without giving the pleats "the wave".
    You might consider adding 1/2" to the apron at the hips and 1/2" to the pleats at the hips in order to give the kilt a bit more girth in the hips so that the apron hangs straighter down the front and doesn't pull in under his tummy.
    2nd August 09
    Maastricht, The Netherlands
    Thanks a lot!
    My own split wasn’t that far off
    But I will use your recommedation.
    Isn’t adding an extra inch to the hips (1/2” apron, 1/2” pleats) causing the weave?
    30th November 04
    Deansboro, NY
    Quote Originally Posted by Dutch piper View Post
    Isn’t adding an extra inch to the hips (1/2” apron, 1/2” pleats) causing the wave?
    No - if you added 1" to the pleats only, it could cause the wave. What you want to do is give a bit more circumference at the hips so that the apron hangs straighter down in the front and the apron-pleats boundary hangs vertically. The way you do that is by adding equally to the apron and pleats at the hips.
    Here's an example of a kilt made with a hip measurement that is too small - the kilt pulls in under the belly, the apron-pleats boundary is not straight up and down, and the kilt is tilted so that the apron edge and first few pleats flop forward at the bottom.
    Here's the same guy with a kilt where several inches were added at the hips, split equally between the pleats and apron:
    2nd August 09
    Thank you Barb,
    I think I will stick to your recommended split.
    I asked him to remeasure his waist and hipsize.
    He came up with 52” hipsize.
    So making a 53” hip already ads 1/2” to apron and pleats.
    If you like, I will post a picture of the kilt when it’s ready. Although that might take a month or two
    30th November 04
    Deansboro, NY
    Sounds good! And definitely post a pic - I’ll be looking forward to seeing it!
