Results 1 to 6 of 6
    Bjordnolf is offline This member has been inactive for more than 1 year
    11th October 05
    help with pleat spacing
    I am planning on making a kilt but have a question as far as pleat spacing goes. Its gonna be a casual kilt but will 4cm spacing with 11cm under pleat spacing work?
    thanks
    Victoria, BC, Canada
    I all depends on what you want the finished kilt to look like and swing like.
    On the Freedom Kilt Cargo Model the pleat 'reveal' (That part you see) is 2" / 5.5cm wide. The distance from 'out'(convex) pleat to the next 'out' pleat is 10" / 25.4cm. (This is called the Sett on tartans) Which gives a pleat depth of 4" / 12cm.
    On the Casual and Dress Models the reveal is 1" and sett is 7" which gives a depth of 3".
    Be advised though, that with this generious a pleat the total amount of fabric for a Casual Kilt is in excess of 8.5 yards. It does give a true kilt swish to it though.
    As a rule of thumb your pleat depth should be 3 - 4 times greater than the reveal.
    www.Freedomkilts.com
    2nd Laird of Lochaber
    30th November 04
    Deansboro, NY
    What's your fabric?
    Barb
    11th October 05
    Carhartt canvas.
    30th November 04
    Deansboro, NY
    Then I'll let others give you their good advice! I'm one of those "tartan-only" kiltmakers!
    Barb
    lennonkiltmakers Guest
    traditional and contempoary kiltmaker
    for a casual kilt mark every 6 inches this is then the centre of each pleat this gives a good swing and also a good amount of pleats.
