25th June 06, 08:30 AM
Please clarify reverse pleats
I'm planning a kilt of denim, and want to understand reverse pleats for this sort of casual kilt. I will be doing pleats of 2 inches reveal and 2 inches deep. At the left apron edge there will be a pleat with a depth of 2 inches, so should the reverse pleat on the right be the same depth? Or would it be better to make one or both of these deeper for functional purposes?
25th June 06, 08:39 AM
Hi Eric
Someone with casual kilt experience should chime in on this, but, in a trad kilt, there is a deep pleat beneath the edge of the apron (it's not really the first pleat, just the fold-back of the left apron edge) that is typically deeper than the other pleats. I try to make mine a minimum of 4.5-5" deep (i.e., uses up about 9-10" of fabric). Gives more freedom of movement to the apron.
On the other side, there's an inverted pleat (the last pleat is normal, but the underapron edge folds under to the left, toward the underapron center, forming a big box pleat, basically). I try to put a good 3-4" in each, partly for movement and partly to give some fabric in case the kilt has to be let out.
For a casual kilt, I don't know what the typical procedure is.
Barb
25th June 06, 01:02 PM
The pleats under the apron are important as they define how far and how easily the aprons will fall vertically when you sit - but also how easily and how far they will fly up.
Now with denim I would not think you would have much trouble with the fabric flying in the breeze, so it might be a good idea to make fairly deep under apron pleats and to have small pleats for a few inches more than half the hip measurement, so that the apron and under apron slide easily and drops between your knees for confident sitting.
For me 2 inch pleats is a bit skimpy - but I tend to be generous in most things. Just be sure that when you sit down there is going to be enough material to go round.
I make my kilts in a reverse Kinguisse style, so the two sides are mirror images, with the small pleats pointing to the back where they meet in a large inverted box pleat. The two aprons are hemmed straight at the edge of the fabric, but shaped within the length, so I make a pleat 2 inches deep which is pressed out so the bottom edge of the aprons are 2 inches wider than at the waist edge, and then I make a large under apron pleat and only then start the small pleats.
This style suits me better than the traditional or the original Kinguisse style with the pleats opening towards the front - I catch then on everything around the garden and even in the house.
25th June 06, 08:12 PM
I know the pleats I plan for this are a bit shallow at 2 inches but I haven't worked with denim so I'm concerned about my sewing maching getting through a lot of layers. I'll have 9 pleats using up 6 inches each so that adds up to 54 inches not including the reverse pleats, which may add another 15 to 20 inches per your suggestions for reverse pleats. With apron that could add up to over 90 inches all around. I'm not sure I can spread my legs far enough to need more fabric than that, but I'll give it a try (ouch). I'd like to have deeper pleats, but until I experiment with denim more I'll take it slowly. Thanks for your suggestions. More are always welcome....
26th June 06, 12:00 AM
It is my personal opinion that denim makes a terrible fabric for kilts. It is a very stiff and unforgiving material. It's ok for jeans because you are inside them, always stretching the fabric out to shape. In a kilt the fabric WILL shrink and pucker. Look at the seams of your jeans, see those puckers? That is what each and every pleat edge you stitch down will soon look like. Unless of course you just love ironing.
Not everyone agrees.
But if you have decided on denim then my comment would be to include as much fabric as you can possibly afford. My work weight kilts have between 7 and 9 inches of "Sett". (depending on model) With a reveal of either 1.5 or 1 inch that makes the pleat depth between 3.5 and 4 inches.
On the left side of the outer apron is the deep pleat. This pleat needs the depth to allow the aprons to hang correctly when standing and to allow room for you to sit and have the apron fall between your legs. On my kilts this pleat is half the depth of the width of the apron.
On the right side of the under apron is the reverse pleat. This is just like the deep pleat but because it also reverses the direction of the pleat it gets a special name. (Think inverted or reverse box pleat). On my kilts this pleat depth is also 1/2 the apron width.
I hope this helps. I'm not trying to discourage you from your endevour but trying to help you from making something which after two washings starts to look like a tutu.
www.Freedomkilts.com
2nd Laird of Lochaber
26th June 06, 09:11 AM
Thanks, Steve. Those are mighty deep side pleats. If my apron is 18 inches wide that would make them about 8 or 9 inches deep. Is that what you meant to say? Hmm. That's like three aprons worth of fabric in front, not counting the inner apron. I'm not trying to cut back on fabric, but I think I'll go more moderate. It seems that for apron-dropping purposes, 4 or five inches deep would be sufficient. That would give 16 to 20 inches of fabric to unfold as knees spread, giving a minimum of 34 to 38 inches to hang knee to knee on me, which is a lot.
I'm thinking perhaps you meant that all the hidden fabric in the deeper side pleats equals half the apron width, meaning for an 18 inch apron they would use 9 inches of fabric and be 4.5 inches deep. Is that right?
Regarding denim seams shrinking, one thing is for sure, they use cotton thread on jeans, which itself will shrink differently from the fabric. Good to point out that hazzard, though. So have you tried doing denim with maybe an all polyester thread, or a blend? Another trick would be to use a zigzag stitch, but that would probably look funny. I have in the past put hems on jeans that never puckered with many washings, so that must have been poly or cotton/poly blend thread.
I also noticed on the jeans that I have that the stitch they use is somehow not just an ordinary straight stitch, so that may figure in as well.
We shall see, we shall see.
I've also been warned by a seamstress to beware of selvage that may have different fibers or weave, and therefore shrink differently than the fabric itself.
26th June 06, 09:53 AM
I did mean a pleat 8 to 9 inches deep for a 16 inch wide apron. If your aprons are properly tapered that depth at the waist is reduced to only 2 or 3 inches at the hem.
In general, amount of fabric = swish. The more fabric, the more weight of fabric to move and hang by it's own weight. That's why traditionals have nearly 8 yards of fabric.
And the extra deep pleats under the aprons means that the aprons will have less tendency to pucker up at the waist or under your sporran. Traditionals have horsehair linings and re-inforcements under the aprons. Contemporaries usually do not. With only two or three layers of fabric in the aprons there is just not enough stiffness there to resist those unsightly horizontal puckers in the front of the aprons.
I did some experimenting with the drape of fabrics when I was designing mine. I found that good kilt wool needs, on average, 6 inches of fabric length to have enough weight to allow the fabric weight to pull wrinkles out of itself.
Denim on the other hand requires 38 to 45 inches of length to do the same thing.
That is why most denim kilts you see seem to stick out at wierd angles after only a few minutes of wearing. The fabric is just too stiff to fall back down under it's own weight.
A note on stitching-Try to use the same fiber content in your thread as is in your fabric. Denim is 100% Cotton. Use 100% Cotton thread. The problem with denim is that the warp and weft threads are different. One is dyed and one is natural. The shrinkage is not even warp-wize
Then back off your machine tension. (both the upper and bobbin tensions.)
The stitches should be as loose as possible to allow the fabric to find it's own natural "Lay". (most home machines have limited tension possibilities and are factory set for thinner and lighter fabrics.)
And while I'm at it, it is not the ability of home machines to punch a needle thru fabric that is the problem, it is the foot height. Most home machines can't lift the foot high enough to get the 14 or 18 layers under the foot.
26th June 06, 03:55 PM
Pleater has suggested narrower-than-traditional aprons so that they actually fall between the knees when sitting. Incidentally, the reverse Kinguisse pleating style she describes is exactly what Utilikilts uses.
The Wizard of BC reminds us that the deep pleat and the reverse pleat appear far too deep at the hip line, but when you add flare to the aprons of 1.5 to 2 inches on each side, the depths at hemline are much smaller.
I have made several cotton casuals with 2-inch reveals and 4-inches hidden. This produces only three layers of fabric below the hip line and makes them very easy to realign for ironing.
My most irritating issue with cotton or cotton/poly kilts has been the "dip," where the hem on the deep and reverse pleats has to be modified to prevent the points from showing beneath the aprons. Because cotton is so unforgiving, the dips canot be handled the same way as wool. Despite several experiments, I still have to reach down and adjust the deep pleats back into place after they have been extended. It has just become a second-nature movement, similar to the sweep before sitting.
Anyway, let nothing deter you from making your own kilt. My first handmade attempt (and several others) is not the prettiest nor most used of my kilts, but it retains an honored place in my closet and it is still used on occasion.
Lady From Hell vs Neighbor From Hell @ http://way2noisy.blogspot.com
26th June 06, 04:52 PM
The amount of fabric you need to go round you whan you sit is perhaps rather more than you think - particularly in a stiff fabric which is going to remain in its folds rather than spread out.
Remember that when you sit there needs to be enough fabric in the front of the kilt to go over the thighs as well as across the lap, and that the weight of the small pleats and the rigidity of the fabric will make them tend to fall back on each side of the hips, outside the thighs.
If there is not enough fabric then there might be a tendency for the aprons to be drawn apart, with distinctly draughty consequences. This might also be a problem if you need to step over some obstacle or up onto a kickstep or just to put your foot up to tie a lace.
26th June 06, 06:31 PM
Actually the "dip" w2f describes is very easy to take care of, but it must be done at the same time you sew the hem. Accurate measuring and forthought is a must.
I would describe how to do this but it is one of those things that makes a Freedom Kilt so distinctive and I'm not sure I want to reveal a company secret.
I will though for a price
And please remember I'm not talking about the length of fabric needed to go around you standing or sitting but the amount of fabric needed to allow the fabric to move on its own. Even with a full width apron large enough deep and reverse pleats will allow the apron to fall between the legs.
