04-23-2010, 02:17 PM
|  | Registered Hobbyist | | Join Date: Jan 2010 Location: Netherlands (expat)
| | | pressing
Hello,
I have a question regarding pressing the kilt, without getting the bump at the side of the front apron.
You can just see what I mean- at the right side, just under the kilt pin. Is there any way to get rid of that, or do I just have to deal with it?
Any help is much appreciated.
Michael
04-23-2010, 02:21 PM
Try reposting your image. You can not use just the image location to get it to work. You have to use a service like Photobucket to do it.
04-23-2010, 02:22 PM
Is that better?
I can see them...
04-23-2010, 03:27 PM
I don't know quite what you mean by a "bump" I can see that the apron seems to have a bit of a hem at the edge which makes it shorter.
Can you get us a closeup picture of that part of the kilt?
04-23-2010, 04:04 PM
|  | Registered Hobbyist | | Join Date: May 2008 Location: San Diego CA
Not quite sure what you're asking, but here's one possibility:
If you are pressing an area that has multiple layers of fabric, try putting a piece of card stock/cardboard/additional folded material etc. in place to "level the playing field." For example, if there's a pleat that ends beneath your front apron, don't just press across the single apron layer and onto the doubled pleat layer -- put something beneath the single-layer fabric so that your iron is pressing across a level surface.
If you are trying to describe some other issue, I think we need more hints.
__________________
04-23-2010, 04:35 PM
| | Quote:
Originally Posted by sydnie7 Not quite sure what you're asking, but here's one possibility:
If you are trying to describe some other issue, I think we need more hints. | Yes, this is what I'm talking about.
Thanks, I hadn't thought about putting something underneath to fill in the void. (now it seems quite logical) Anyway, its always worth asking for advice when it comes to such a valuable item of clothing.
Michael
04-23-2010, 04:41 PM
I'm not an expert in any of this, so I may be way wrong.
It sounds like this is in an area that can also be pressed from the back side of the apron. This will keep the front side of the apron even. Still use a damp pressing cloth, though. Just a different way of pondering the issue...
__________________
04-24-2010, 07:47 AM
I think you are on the right track, pressing with leveling the field. If that doesn't give satisfactory results, try it with a pressing ham. You will then be pressing in a radius to the front apron so it will help it curve around. You can also use a rolled up towel and will be good for experimenting.
__________________ Wallace Catanach, Kiltmaker
and Professor A day without killting is like a day without sunshine. |
04-24-2010, 09:36 AM
|  | | | Join Date: Oct 2004 Location: Page/Lake Powell, Arizona USA
Use a steamer instead....
__________________
Lifetime Member Scottish Tartans Authority, Owner Freelanders #4 & 5 PhotoBucket Album "I'll have a kilt please, a nice hand sewn tartan, 16 ounce Strome. Oh, and a sporran on the side, with a strap please." |  | | X Marks Advertisers |  | For Quality Scottish Made Products at Affordable Prices |  |  | | | | Thread Tools | Search this Thread | | | | | Display Modes | Linear Mode |
Posting Rules
