12th August 07, 10:47 PM
Proper description of kilt dimensions?
Hello all,
Plenty of instructions can be found on measuring oneself for a kilt, but it's not entirely clear how these measurements translate into the finished product. Is there a good definition sketch available that illustrates all of the main kilt terminology and dimensions?
The reason I ask is that I thought the drop was the same as the total length of the kilt. However, a recent post by Barb T. indicated otherwise, and it seems that the drop refers to the length of pleated material, not counting any waistband or similar that might appear at the top of the kilt. I checked on-line sources but could not find a definitive answer so thought I'd ask here.
12th August 07, 11:05 PM
All the terms we use to describe our kilts are not yet standardized. Especially since the advent of Casual and Contemporary Styles. Each kiltmaker uses most of the same terms but how those terms are applied is kinda fuzzy.
To Barb who is trained as a Traditional Style Kiltmaker the term Drop is used to define the length of the kilt from the hem up to the middle of the top strap.
Above the middle of the top strap the kilt is no longer tapered but flares back out. This area is called the Rise. Barb uses a 2" rise. Some old military kilts had a 4 or more inch rise.
When measuring for a kilt to be made by Barb you would measure from your natural waist down to the hem. She will then add the rise.
This system is not universal. This is why each kiltmaker here will tell you "USE THE MEASUREMENT SYSTEM OF THE KILTMAKER WHO WILL BE MAKING YOUR KILT. NEVER USE SOMEONE ELSE'S SYSTEM."
For example, I use Drop to define the total length of the kilt from the top of the waistband to the bottom of the hem. But then, I don't make Traditional Style Kilts. My kilts have a waistband similar to a pair of trousers so the rise is already built in.
The best advice anyone can give you is ask your kiltmaker what method they use and what definitions of the terms they like.
As far as other terms you may have heard I would suggest finding a copy of Barb's book "The Art of Kiltmaking". This is the standard. It will give you all the information on the parts that make up a kilt and will get you informed enough to ask the right questions of your kiltmaker.
www.Freedomkilts.com
2nd Laird of Lochaber
By MacHenderson in forum DIY Showroom
Last Post: 28th June 07, 11:49 AM
By Yeti in forum DIY Showroom
Last Post: 19th June 07, 02:33 PM
By Geoduck in forum How to Accessorize your Kilt
Last Post: 16th February 05, 01:28 PM
By Will in forum Comments and Suggestions
Last Post: 17th December 04, 09:45 AM
By Dreadbelly in forum General Kilt Talk
Last Post: 6th September 04, 10:11 AM
