Results 1 to 6 of 6
    Amoskeag's Avatar
    Amoskeag is offline This member has been inactive for more than 1 year
    20th November 07
    Deerfield, NH
    1st Homebrew Kilt
    Here is the finished product of the bedticking kilt. I have a whole bolt of this stuff and it seemed reasonable to experiment with this instead of valuable wool. It is mid-weight cotton and is about 5 yards. I had been sitting on it for a while so the pleats are kind of messed up. I'm at work and I don't mind "splashage" on this one. I plan to use it for hiking so I used Velcro so as to not have straps and buckles under the waistband of the pack.
    The belt is my old fire department uniform belt. The sporran is one I made for18th C. reenacting. The rest is just my work clothes. (Note to self: make sure your stockings are even)
    15th April 07
    State College, PA
    Very interesting. It is always a good idea to use practice material for the first kilt.
    30th June 04
    Houston, Texas
    Dang, that's a very impressive first effort! Any gripes, moans, bitches or complaints would be unseemly. Maybe extend the fell down some? But dang, that looks like a kilt! Good show.
    And the Gods of the Copybook Headings said: "Stick to the Devil you know." Proud member, Order of the Dandelion
    15th July 07
    California
    Neat - you ended up with a tweed effect. It seems you have a good "knock-around" kilt.
    What lessons did you learn? What will you do differntly next time?
    Bit of curl on the reverse pleat but that might be from sitting on it. But heck you just banged out a perfectly good kilt on your first try. Good on ya!
    Amoskeag's Avatar
    20th November 07
    Deerfield, NH
    Thanks for the comments. I'm going to stitch the fell down more. The reverse pleat has too much material in it. There is nothing I can do about it now but future kilts will use a narrower reverse. The pleats could use a little more taper as well. This material is pretty stiff, I washed it once before I worked it. I will need to clean it again and we'll see how it survives the washing machine. It actually works out pretty nicely at work, it gives all the biddies at town hall something to gossip (wonder) about.
    Bob
  1. First Kilted homebrew session.
    By Rygar in forum Show us your pics
    Last Post: 27th June 07, 10:42 PM
