Results 1 to 10 of 18
Thread: Dirk
    16th August 06
    Paisley, Scotland
    Dirk
    I have a nice dirk, a bit plain but it looks good, I was thinking of getting a new one but I thought about replacing the handle.
    Now the easiest way for me would be if someone here knows if anyone makes them and how easy it would be to replace the handle or would I just be better off getting a new one.
    I would prefer some kind of horn made handle.
    Thanks in advance.
    alikws is offline This member has been inactive for more than 1 year
    10th March 08
    southern vt
    How is that dirk put together? With riveted scales like a green river knife, a tang driven into a turned handle like a plug bayonet, or washers stacked, then fastened with a pommel, like a k-bar?
    4th March 08
    gastonia nc
    post a pic and then we'll know how to proceed...thanx
    ~oz
    16th August 06
    Paisley, Scotland
    I'm a total novice when it comes to thing like this so here's some photos as suggested.
    4th March 08
    gastonia nc
    wow...i'm not sure i'd change a thing on that one !!!It looks like a threaded pommel cap to me, you should be able to twirl it off and remoce the hilt fairly easily, but i'd just get a blade and start fresh...that one is a beutiful dirk
    15th April 07
    State College, PA
    It looks like it might be a full tang blade. Does the very top knob unscrew?
    27th October 07
    Fairbanks, AK
    I would not try to redo this one. It looks good already. I'd suggest you get a blade and make a new one. Seriously. The one time you will REALLY want to have a dirk on, you'd have your one dirk in a half-completed state and no options for getting one on your hip.
    Something else that can be fun, depending on your budget, is to get a couple of blades and make dirks that go with different kilts. For example, if you have kilts in browns, make one with a maple handle and finish to match a brown kilt, then make another one with a handle that goes well with another kilt, but with the same blade, same handle shape, etc. I personally don't like sheathwork (though I am fairly good at it, of necessity) so I'd make one sheath that would fit either dirk. Voila! You can coordinate your outfits even better!
    Or, just get a blade or two and have some fun. But keep the current dirk, unless it really doesn't mean anything to you.
    -Patrick
    10th June 07
    Solingen/Germany
    Hi,
    It´s a CasIberia dirk, right?. I got one as my first dirk. But to be historically accurate the handle is much too thick and far too long. I shortened mine by cutting away the pommel cap. It´s brazed, not screwed. I sawed it off, after that the pommel,too (you´ll need it again) Then I sawed the grip off at 2`from the top. Stop sawing when you feel touching the tang. After that I cracked the waste material off. Then you will be able to tap the tang. Put on the sawn-off pommel again and fix it with a new brass nut. In the end you´ll just have to shape it as you like it. I gave a simple carving to my own one.
    I´ll try to post some pics soon.
    Thomas
    By the way- That celic stone in your pictures looks really fantastic. Is it your own work?
    9th February 08
    Seattle, WA
    Atlanta cutlery sells dirk blades for 16.96 get one and then work on a handle. Leave your current blade be.
    http://www.atlantacutlery.com/atlant...il.aspx?ID=824
    16th August 06
    Paisley, Scotland
    Thanks guys, I bow to your experience and will leave it alone. I was at Culloden this weekend and saw some lovely Dirks and it just got me thinking.
    I've never done anything like this before but I may well get a blade and see what I can do.
    I've tried unscrewing the bolt at the end but it doesn't seem to want to budge.
    The stone was carved by a good friend of mine called Ron Henderson, he has a page on my site here
    http://www.thesonsofscotland.co.uk/ronsstones.html
  1. New Dirk
    By PiobBear in forum DIY Showroom
    Last Post: 2nd March 08, 02:42 PM
  2. New Dirk
    By acstoon in forum How to Accessorize your Kilt
    Last Post: 30th August 07, 07:01 AM
  3. New dirk!
    By kevinkinney in forum How to Accessorize your Kilt
    Last Post: 4th June 07, 12:01 PM
  4. My First Dirk
    By Oatmeal Savage in forum How to Accessorize your Kilt
    Last Post: 21st September 06, 07:39 AM
  5. Dirk
    By Casey in forum How to Accessorize your Kilt
    Last Post: 7th October 04, 10:43 AM
