Results 1 to 10 of 11
Thread: DIY Cantle?
    24th April 07
    Duluth, MN
    DIY Cantle?
    Howdy all,
    Call me a bit nutty, but I came across one of these in the store...
    ...and my mind saw a stainless steel dress cantle made from 1/2 of the lid. It's too bad that they are only 5" wide.
    Kevin.
    Institutio postulo novus informatio supersto
    Proudly monkeying with tradition since 1967.
    18th February 05
    Spokane, WA
    So, you're a bit nutty. Tell us more about your idea, please.
    7th July 06
    Roswell, Georgia USA
    If anyone can do it Kevin, you are the one.
    24th April 07
    Duluth, MN
    Here's my thought:
    The cantle seems to be the big piece missing when any of us sit down to craft a dress sporran. We can invest a chunk of $$ in buying a nice one, scavenge one from an older sporran, or cobble one together on our own. Personally, I'm getting tired of braiding mine. I want shiny metal to play with. I've toyed with the idea of making a good silicone mold and pouring them from pewter. But that means having to learn yet another skill at the expense of work time. It would be much faster to cut one from a nicely polished piece of stainless steel that's already the correct size and shape. Then I need only determine how to mount it on the bag....which won't take much. Think of how well it might accept engraving by a local shop.....
    More to follow I'm sure.
    Kevin.
    16th September 08
    Charleston SC
    I like where your going with this kevin.
    please continue.
    Whisky for the gentlemen that like it. And for the gentlemen that don't like it - Whisky.~Major Jock Sinclair-Tunes of Glory
    5th November 08
    Marion, NC
    You might also want to look at pie crust shields. They're shaped just like that lid, except the center is already cut out. You can probably find them in stainless, and if not, one might make a nice practice piece to work out the engraving.
    I'm wanting to see how this work out!
    --dbh
    24th July 08
    San Jose, CA
    I think pie crust shields might be on the large side, unless you could find pot pie size ones. Do they make those??
    Bob
    24th April 07
    Duluth, MN
    So, we'll start with this.
    ...and kill two birds at once. I'll use the lid for cantles, and the body for a camping water heater- spout on top, stainless wires through holes in the lip, hung over the campfire- pour cold water in, an equal amount of hot water comes out the top spout.
    While I'm at it, I'll probably make the cantle easy to remove, so I can switch it from bag to bag. Does anyone have a suggestion for matching stainless cones?
    Kevin
    PS-
    1st May 09
    Connecticut
    Kevin, I like the way you think! Last year I was in a junk shop and came across a brass stamped tray that seemed about 6"-7" dia. and about 1/2" high. I got it for 50 cents and had the idea of making a Victotian stye hinged sporran. Well, I've got it 95% done and only have the latching catch to figure out. I think it's coming out pretty good for a first attempt and will post pictures as soon as the latch is done.
    So keep on looking and you may find the perfect item to use. I think that 6 1/2" dia would be the smallest I woul use. My tray was 7" dia and that seems about right to be able to get you hand into the sporran.
    I do want to get it done for the New Hampshire games next month. I even left the old brass patina to keep with the vintage look.
    Good luck with your search.
    Scott
    24th April 07
    Duluth, MN
    No dice on this route.
    The dimensions were not correct. The diameter was stated at 5.75" which is close enough to 6" to go. It turned out just about 5 1/8" wide. Atleast it will look nice in the privy.
    Kevin out.
  1. Wood cantle?
    Last Post: 13th January 09, 12:01 PM
  2. Jazzy Cantle
    By Dukeof Kircaldy in forum How to Accessorize your Kilt
    Last Post: 27th April 08, 12:35 PM
  3. Cantle
    By James MacMillan in forum How to Accessorize your Kilt
    Last Post: 11th February 08, 06:46 PM
  4. old cantle to new sporran
    By Joe Gondek in forum How to Accessorize your Kilt
    Last Post: 27th June 06, 02:26 PM
