Results 1 to 10 of 16
    5th June 08
    Boise, idaho
    DIY flashes idea
    My idea was to sew the flashes right onto my sock. I would only need 4 5" pieces of material this way and wouldn't have to buy the adjustable things that go around the calf or even buy velcro. I have no money to spend at all. I'm looking for some discarded material around the house I can use if possible but something that won't wrinkle as easy when it's in the wash. I was thinking of a linen type of material that they use for tablecloths etc. in most restaurants might do the trick (doesn't seem to wrinkle as much as other materials). I was going to simply sew then onto my sock with just a simple hand stitching. My socks were over the calf and I have about 5 pair of them so if this doesn't work I don't mind just throwing it away. Does this sound like it might work? Also are they about 1.5in wide typically? I'm just going to start with black material that will go onto my white socks. Later on if this works will do a red material onto my black hose socks.
    I would urge caution as, from experience, sewing anything woven onto something knitted usually results in the knitted item being damaged or the sewing stitches pulling out of the material.
    I think it is because the two structures deform differently, particularly when being washed.
    Also, real linen is very prone to creasing. It is notorious for it, so chose your fabric carefully.
    It could be a case of penny wise and pound foolish - a UK proverb indicating that in an attempt to save a small amount you incur a greater loss.
    Anne the Pleater
    chasem's Avatar
    chasem is offline This member has been inactive for more than 1 year
    30th March 05
    Near Santa Fe, New Mexico
    I don't think this is the best of ideas. Going this route, you lose the ability to coordinate, as you're stuck with what you've sewn. I'd say that you'd be better off saving up for a few different colors of flashes, instead, or sew your own flashes, which can also be done at very low cost.
    Victoria, BC, Canada
    The original idea of flashes was the ends of the garters used to hold you socks up. Today we use elastic for garters and the flashes are just "a splash of color".
    By sewing your flashes onto your hose you bypass the garters. Why? If you don't use garters what holds your hose up?
    It's the garters that are the important part. Leave the colored flashes off, or change them up for a different outfit. That's the beauty of it all.
    I usually don't wear the flashes, but I always wear garters.
    www.Freedomkilts.com
    2nd Laird of Lochaber
    3rd November 08
    Boise, Idaho
    My thoughts exactly!
    The fear o' hell's the hangman's whip To laud the wretch in order; But where ye feel your honor grip, Let that aye be your border. - Robert Burns
    5th June 08
    Boise, idaho
    re
    Well I'm going to to it anyway despite the approval of this board. And I got to add I think black flashes would look good with any kilt. I never really liked the look of flashes that match the kilt. It's just my wierd opinion.
    30th November 04
    Deansboro, NY
    Don't you have trouble with your kilt hose falling down?? If I didn't wear the garter part, my kilt hose would be sagging and looking unsightly in about 5 minutes, particularly the one with the sgian dubh.
    15th April 07
    State College, PA
    I've sewn some velcro onto the back of the flashes, the side with the hooks. They stick to the sock pretty well. You can then remove them easily and try different colors, tartans, etc.
    20th December 04
    Charlottetown, PEI
    and what about washing your hose? Will that ruin your sewn in flashes?
    Sewing a flash on means you can never wear your hose scrunched down casually either.
    I say "don't do it"
    Inside me is a thin woman screaming to get out. But I can usually shut the b*tch up with chocolate!
    M. A. C. Newsome's Avatar
    Contributing Kilt Historian
    26th January 05
    Western NC
    You can buy elastic by the yard at most any fabric store. It's fairly cheap. The easiest way to make your own garter would be to sew a couple of patches of velcro to the elastic. Making your own this way is not expensive at all, and you'd have a garter to keep your socks up!
    Matthew A. C. Newsome, GTS
  1. Idea!
    By GreenDragon in forum General Kilt Talk
    Last Post: 25th May 07, 05:04 AM
  2. There went that idea.
    By Erisianmonkey in forum DIY Showroom
    Last Post: 20th May 07, 03:12 PM
  3. Hat Idea
    By Nick in forum How to Accessorize your Kilt
    Last Post: 12th February 07, 06:16 AM
  4. style question - tartan flashes, solid flashes or no flashes?
  5. Bright Idea, Old Ties to Flashes
    Last Post: 9th December 05, 07:29 AM
