Results 1 to 10 of 19
    7th December 06
    A Duct Tape Kilt
    I am currently trying to make a kilt out of duct tape. Any suggestions on how to make the pleats?
    Happiness is like peeing your pants. Everyone can see it, but only you can feel its warmth.
    5th September 05
    Chicago
    I dunno exactly how to put it together but you might want to check these guys out for supplies:
    http://www.duct-tape.com/?gclid=CLuB...feEQ#DUCT_TAPE
    ...so many colors! ooooooooooh! Maroon!
    Best
    AA
    7th December 06
    Quote Originally Posted by auld argonian View Post
    Best
    AA
    I'm doing this one in plain silver to see if it works. If it does, then I'll try to make a tartan with duct tape.
    Archangel's Avatar
    Archangel is offline This member has been inactive for more than 1 year
    27th June 05
    London, Ontario, Canada
    Somewhere here there is a thread that got into that. There were some pics of Roman style skirt things. You might want to look around for that.
    Basic rule: the higher up you go, the more careful you have to be to not have sticky stuff.
    7th December 06
    Quote Originally Posted by Archangel View Post
    Yeah... Im tempted to do a fleece lining...
    16th July 06
    Sierra Vista, Arizona, USA
    I was thinking that the pleats could be a double layer of tape and hinge on a single thickness. Each pleat would be double the width with a reveal of one width. In the cruddy diagram below, I'd use double thickness for the lines and a single piece with the sticky on the inside fold would keep the pleats from splaying. You could taper the fell by not using an inside piece of tape and then line it with tape after tapering. Heck that almost does it. For a tartan effect alternate horizontal and vertical piece to achieve a desired pattern.
    ______
    <___
    ______>
    On an interesting aside, I grew up in Wasilla, Alaska. It has the distinct honor of being the "Duct Tape Capital of the World" The Wal-Mart in Wasilla sells more duct tape than anyplace else in the world. O'Neille
    emolas's Avatar
    emolas is offline Oop's it seems this member needs to update the email address in their profile.
    16th May 07
    Nashua, NH
    Here it is
    It's got a couple of pictures and everything.
    There are 10 kinds of people in the world...
    Those that understand binary, and those that don't.
    Sean_the_Kilted's Avatar
    Sean_the_Kilted is offline This member has been inactive for more than 1 year
    16th March 07
    Heidelberg, Germany
    here is a link to a duct tape kilt http://dalmatianalley.com/kilt.htm
    7th December 06
    Thanks for the help, guys. I'll post some pictures when it's finished.
    16th December 05
    Maryland USA
    Here's how I'd do the pleats:
    make the "fabric" using strips of
    duct tape running from the waist
    to the hem. Lay first strip sticky
    side up. Second strip sticky side up
    beside the first. Third strip sticky side
    down covering half of each of first two
    strips (leaving half of sticky on each one
    showing).
    Add another strip sticky side up beside
    the second strip, and another one sticky
    side down beside the third one (again
    overlapping half of the sticky on two).
    When you get to a pleat:
    Lay one strip sticky side up.
    Lay one strip sticky side down
    covering only half of the first one.
    This gives you a strip with half
    sticky showing on each side.
    Place the sticky of this piece over
    the sticky showing on the main
    kilt but going in the opposite direction.
    Continue in the opposite direction until
    the pleat depth is sufficient, and reverse
    again.
    The amount of "seam" at the reversal
    will be half the tape width. If you think
    that is too much, trim it. Probably
    1/4 to 1/2 inch is plenty to hold it
    together.
  1. Duct-tape sporran
    By toadinakilt in forum How to Accessorize your Kilt
    Last Post: 22nd March 06, 08:44 AM
  2. Scotch Tape - What Tartan?
    By MacMullen in forum Contemporarily Made Kilts and How to Wear Them
    Last Post: 21st December 05, 07:55 PM
  3. Duct tape kilt
    By Cthulhu in forum General Kilt Talk
    Last Post: 17th June 05, 10:06 PM
