Results 1 to 10 of 12
    15th April 07
    State College, PA
    The evolution of modifying jackets
    (into a kilt jacket)
    One man's story.
    My first project was to take a tailcoat and convert it into a “Prince Charlie” jacket.
    Thread found here: http://www.xmarksthescot.com/forum/kilted_pc_conversion-t30378/index.html
    The good:
    It was wearable to my daughter’s wedding. Found here
    The bad:
    The washers were heavy! I used fender washers.
    I did not make the crail type sleeves for the sleeve buttons.
    The epaulettes were not sewn into the seam of the shoulder and the button was sewn to the epaulettes without a buttonhole. (This was quick and easy.)
    Lessons Learned:
    Don't shortcut, I want to go back and add the button holes to the epauletts and attach the sleeve stuff.
    Jacket #2 to follow.
    22nd November 07
    Desert SW USA
    Fender washers?
    * I see your post with the answer. *
    15th April 07
    State College, PA
    Quote Originally Posted by Ted Crocker View Post
    Fender washers?
    Fender washers were developed for fenders on a car??? anyway they are larger than standard washers to hold on light weight materials like plastic and wool.
    15th April 07
    State College, PA
    Jacket #2
    Thread found here:White PC Jacket
    All I did was cut off the tails and re-sewed.
    The good:
    Relatively easy.
    The bad:
    Where to wear?
    22nd June 08
    Indiana, USA
    Quote Originally Posted by ChattanCat View Post
    I use pennies, they weigh just enough to give the SWK thrifty that all too necessary swoon
    Hector Rojas Young | Chilean-Scot
    operor non sentio mihi , quinymo agnosco mihi
    Clan Young - We Ride!!
    15th April 07
    State College, PA
    Quote Originally Posted by hospitaller View Post
    So how many pennies does it take for a SWK> swoon!
    15th April 07
    State College, PA
    Jacket #3
    This one has a lot of functionality and with a little work. It was a patch pocket jacket. I removed the pockets, cut the jacket down, and reattached the pockets. I used bias tape to shape the bottom of the jacket.
    The good:
    Only shortened the jacket, move the flaps, and re-sewed the bottom
    Thread: Jacket #3
    Also added the slit flaps:
    The bad:
    Really haven’t found any yet.
    Lesson’s learned:
    Don’t press to hard on the jacket. The bias tape had folds in it that impressed onto the front when I pressed. I am used to pressing kilts and it takes a lot of pressure for setting the pleats in a kilt.
    22nd November 07
    Desert SW USA
    That bias tape sounds like good stuff. I ended up using origami jacket folding techniques on mine because I didn't have any.
    15th April 07
    State College, PA
    Jacket #4
    Dongal tweed
    I like the material of the dongal tweed because it was a loose, heavy material. I used the material from the bottom of the jacket for the cuffs.
    The good:
    Dongle tweed!
    The bad:
    Had to cover the slash that the pockets left with the pocket flap.
    I used fusable fabric on the inside of the jacket to hold the pocket slash together.
    No epaulettes.
    I did not put the roll of fabric on the cuffs by the buttons. I really like the way the rolled lines look and may go back to add the roll.
    15th April 07
    State College, PA
    Jacket #5 is in progress and will post when it is completed.
  1. Evolution of a kilt wearer
    Last Post: 2nd July 08, 08:47 PM
  2. Evolution of a Kiltie - Changing Tastes
    Last Post: 18th April 08, 02:08 PM
  3. Kilted Evolution, Part sixteen thousand and three
    By Kid Cossack in forum General Kilt Talk
    Last Post: 17th June 07, 08:54 AM
  4. Your evolution in the kilt
    By Richland in forum General Kilt Talk
    Last Post: 15th April 06, 05:13 PM
  5. Evolution.....
    By Blu (Ontario) in forum General Kilt Talk
    Last Post: 9th August 05, 01:14 PM
