Results 1 to 9 of 9
    14th May 08
    Slovenia
    Help me on "artificial leather"
    I found a leftover of leather imitation material 0.8 x 1.4m. It cost me a bit more then nothing ($2). It looks and it feels very much like light soft leather. I thought I could use it for pouch sporran.
    Please, look those 2 photos and advise me what pattern to use. Or maybe something else could be made out of it?
    Thanks!
    Mipi
    13th June 08
    Victoria BC
    I've used "pleather" a fair bit making different sporrans. What I suggest is pick or make a pattern then sew up a sporran out of a different cheap material to see what your finished product will look like. This way you can fine tune your idea before pulling the leather out and making the good one.
    J. Wagner
    http://www.survivorsedge.ca
    "Through the mud and the blood to the green fields beyond"
    "Ne Oblivescaris- Never forget!"
    The outside looks good - but I think that the inside lets it down - I'd be tempted to use some faux suede to line the pouch completely in a fawn or tan colour, or at least some shade of brown, to improve the illusion of it being leather.
    Anne the Pleater
    31st December 05
    Comes from artificial cows. Pleather cows.
    14th May 08
    Slovenia
    Those atrificial cows have this funny blue skin on inner side. I'll use some faux suede (faux leather faux suede) for sure. This will add some ware resistance to the pouch, too.
    Thanks!
    I just thought - if you need to stiffen the edges or flap of the sporran - sometimes artificial alternatives have properties which are different from the real thing, plastic bottles from milk or juice are often very useful.
    I am assuming that you have plastic bottles for these, not paper ones, though they might be of some use, but I have used the plastic bottles in the past, first ironing them to remove the bends, and then using a naked flame to round the edges and then further heat to create any necessary shaping. Sturdy scissors, not the best dressmaking scissors of 'she who must be obeyed', or a craft knife should do the trick cutting up the bottle.
    Iron between pieces of cooking foil, just in case you overdo it and weld the iron to the ironing board cover - minus one thousand Brownie Points for that, not a good idea.
    Crank the temperature up slowly and iron patiently until you achieve the required alteration.
    Anne the Pleater
    5th November 08
    Marion, NC
    As it looks like this material is pretty soft, one of the "Rob Roy" type sporrans might be your best bet.
    --dbh
    13th June 08
    Victoria BC
    When I make mine I sew the inner to the outer inside out, then flip it so it hides the seams, then fill the hollow with a shaped piece of craft foam sheet cut to the sporran shape. You can get the foam ( about 1/8" thick ) at any Walmart or craft store really cheap. I do the front and back of the sporran seperately, fill each with the foam to give it some thickness and stiffness, then sew both halves together. With some experimentation and fine tuning you can make some rather nice and very inexpensive pouches.
    J. Wagner
    4th September 08
    Thayne, Wyoming
    Truer words have never been spoken. Just ask my husband what I thought of him using my best pair of sewing scissors to cut a sheet of tin.
    --Chelsea McMurdo--
    This post is a natural product made from Recycled electrons. The slight variations in spelling and grammar enhance its individual character and beauty and in no way are to be considered flaws or defects.
  1. Artificial Dandelions
    By Zardoz in forum How to Accessorize your Kilt
    Last Post: 26th September 09, 03:49 PM
  2. Leather Questions (Tandy/Leather Factory)
    By Cat in forum DIY Showroom
    Last Post: 23rd February 08, 01:40 PM
  3. Need Leather
    By ChromeScholar in forum DIY Showroom
    Last Post: 6th August 07, 06:26 PM
  4. how much leather
    By Scottishrebel in forum DIY Showroom
    Last Post: 28th January 07, 09:13 PM
  5. Leather
    By Jewddha in forum Miscellaneous Forum
    Last Post: 3rd January 06, 03:38 PM
