15th September 09, 01:39 PM
How to modify a belt buckle...or make it work?
Relating to this thread...
http://www.xmarksthescot.com/forum/a...109/index.html
I've seen quite a few buckles I like, but they don't secure like a kilt belt buckle.
Would it be easier to modify the buckle (or have it modified), or use a "ranger"-style belt with the appropriate parts for the standard p@nts buckle?
Thanks,
Sean
15th September 09, 02:04 PM
well, my two cents is it is much easier to modify leather rather then metal.
The real question is, how big a belt does it take? Most of those style buckles are for 1" to 1-1/2" belts. Which is not near big enough for a kilt (in my opinion).
So,
option A: custom leather work to affix the buckle to a 3" belt, with some mods on the otherside to handle the pin or hook that the buckle probably has.
option B: have a buddy grind of the hook and weld or epoxy a kilt-style hook. You'll still have to do the leather mod.
option C: get a kilt buckle blank and learn to etch or chisel
lots of options really.
Barnett (House, no clan) -- Motto Virescit Vulnere Virtus (Courage Flourishes at a Wound)
Livingston(e) (Ancestral family allied with) -- Motto Se je puis (If I can)
Anderson (married into) -- Motto Stand Sure
Frame Lanarkshire in the fifteenth century
escher-Photoplog
15th September 09, 02:11 PM
Need more information on the buckle as stated above. What size belt it fits. If it's 1" 5/8" one can make a ranger belt for a 2 1/2" kilt belt and it will work just fine
15th September 09, 04:19 PM
Another option that has not been suggested is to grind off the pointy parts on the back of a trouser belt buckle and solder onto the waistplate of a Kilt Belt.
Simply use a plain waistplate to start with. Anyone with any experience soldering jewelry should be able to do this for you.
Remember to use silver solder and not the type used for electrical work. Also avoid epoxy. Both of these methods will result in you buckle popping off and being lost or damaged.
www.Freedomkilts.com
2nd Laird of Lochaber
15th September 09, 04:31 PM
I think that soldering will hold up to the wear and pressure a belt buckle will take. Silver solder is not a fix all product it all depends on what the buckle is made of. I have had some luck when the buckle is steel in welding new tabs on. Also some of the industrial epoxy not the epoxy that you get at Home Depot work.
15th September 09, 08:35 PM
I took a brass kilt buckle and mounted this USMC item simply by drilling a small hole in the buckle inserting the post and screwing on the spinner (small nut used by the Corps) - simple and secure
By sorcererdale in forum Kilt Advice
Last Post: 8th May 09, 06:16 AM
By mycoleptodiscus in forum Professional Kiltmakers Hints and Tips
Last Post: 17th April 09, 06:07 AM
By David White in forum How to Accessorize your Kilt
Last Post: 16th May 08, 08:35 AM
By haukehaien in forum How to Accessorize your Kilt
Last Post: 28th February 07, 05:32 PM
By Scotexan21 in forum Show us your pics
Last Post: 23rd January 07, 02:57 PM
