Results 1 to 10 of 13
    29th April 09
    Texas
    Keeping pleats in place
    My rogue is being fussy about his kilt. Every time he wears his Cotton/Poly X-kilt he wrinkles his pleats. He hands it to me to press. Thankfully because I'm always sewing; therefore, I have the ironing board out but he wants to keep them sharp all the time. BTW, I did the sharp stitching on the outside and inside pleats when I made it. I told him it isn't going to happen unless you have the special chemicals that Dockers themselves has. He wants to starch his kilt, which I told him was a VERY bad idea.
    Any suggestions on how I can keep the wrinkles out of his kilt? Or do I just get to make him a new one with a different fabric?
    I have used spray starch on some of my cotton kilts with good effect - but some materials are always going to wrinkle if they are sat on.
    If he is going to be so persnickerty then I suspect that wool or wool blend fabrics are the way to go - unless you make him sit on a stool and flip the pleats so they hang down the back rather than be rumpled.
    Anne the Pleater
    21st June 06
    San Francisco, California or there abouts
    Has he learned to "sweep his pleats" when sitting? (See below) It can make a big difference.
    http://www.xmarksthescot.com/forum/v...x.html?t=20913
    Best regards,
    Jake
    (|):=' Less talk, more monkey! ,=:(|)
    19th March 09
    Astatula Florida
    My wife solved that problem long ago. I take care of me own KILTS!
    18th December 06
    Burlington, Ontario, Canada
    People, people, keeping pleats in place has been a problem that goes far beyond the time that pleats were invented. Kit makers the world over have addressed this problem with a specially designed stitch called a pleat basting stitch. So proud of this stitch they are that they even use a contrasting thread for it to show. The problem is that kilt purchasers inadvertantly remove this stitching causing the pleats to go all willy-nilly. And what do they expect? Warning: Removing this stitching voids pleat warrantees. Am I the only smart one here on Xmarks and leaves those stitches in?
    The Grant.
    29th April 09
    Texas
    No I don't think he "sweeps" his pleats. He is very mindful of the front. This is the same guy who won't listen to me when I say "Avoid walking over air vents". "Be careful when you turn around from your desk. mom's tell their daughter's to keep their knee's together for more than 1 reason."
    I think he is just going to have to learn how to wear a kilt properly, and know what happens when you don't.
    attworth's Avatar
    attworth is offline This member has been inactive for more than 1 year
    9th June 08
    Fort Worth, TX
    You should show him that link posted above. It's an "instructional video" on how to sit properly.
    The idea is to use your hand to sweep the pleats towards the back of your legs while you sit, preventing them from getting crinkled up underneath. If done properly, there's plenty of time to reach forward and pull/push the apron down. If the sporran is worn correctly, it also helps keep prying eyes from seeing that which shouldn't be mentioned....
    I've noticed that box pleats are slightly harder to sweep properly while sitting.
    Cameron
    31st May 08
    dc
    Yes - sweep deliberately and properly. I think starching would not be a bad idea either.
    The rotate and reveal problem can be reduced by increasing the size of the under apron pleats so that the aprons fall easily between the knees when sitting.
    It is also useful in a kilt used for hiking or active pursuits as it gives the freedom to step up or over without the aprons tending to part company with eachother.
    Anne the Pleater
    M. A. C. Newsome's Avatar
    Contributing Kilt Historian
    26th January 05
    Western NC
    Quote Originally Posted by attworth View Post
    In my experience the opposite is true, at least in regards to a four yard box pleated kilt. I find these much easier to sit in and keep the kilt wrinkle-free than a typical 8 yard knife pleated kilt. Others who own both kinds of kilt have shared the same observation with me.
    As to the original question of how to keep your kilt wrinkle free, I think wrinkles are just something you are going to have to live with in a cotton or poly-cotton kilt. Wool doesn't wrinkle nearly as much. And heavy weight wool wrinkles far less than lighter weight wool.
    If he wants a neat, sharply pressed appearance in his kilt, I'd recommend a good quality heavy weight worsted wool. It can't be beat.
    Matthew A. C. Newsome, GTS
  1. Keeping up with the Joneses
    By CDNSushi in forum General Kilt Talk
    Last Post: 10th February 09, 12:03 AM
  2. Keeping it in the family
    By NatoBro in forum Show us your pics
    Last Post: 30th August 07, 05:55 AM
  3. box pleats compared to knife pleats, cloth usage
  4. Keeping pleats pleated
    By Dirka Skene in forum Kilt Advice
    Last Post: 12th February 07, 05:17 PM
  5. Keeping It Clean
    By Uncle Ricky in forum Kilt Advice
    Last Post: 2nd February 05, 09:18 AM
