Results 1 to 6 of 6
Thread: Kilt Pin
    10th February 08
    St Peters, MO
    Kilt Pin
    Decided to try my hand at turning a basic kilt pin out of a piece of white ebony I had laying around. Here is what I came up with...
    Next time around I may try and get fancy with it.
    "just as the Son of man did not come to be served, but to serve, and to give His life as a ransom for many." Matthew 20:28
    23rd September 10
    Idaho
    Hey, that's great. I'ved carved a couple but had not turned one yet.
    Thanks for the inspiration!
    10th February 08
    St Peters, MO
    On the next one I plan to remove that large hunk of plastic over the pin and use epoxy and small brass screws to hold it to the wood. For now, as a learning project, I'm happy with the results.
    23rd September 10
    Idaho
    I just use 5" epoxy for the several I've made. So far no problems with them coming loose.
    15th September 10
    Indiana
    It looks pretty good. I like the different and original designs for kilt pins. It gives the wearer some individuality...not that the kilt doesn't already do that, unless you are with a rabble of kilties.
    I would recess the pin into the wood a little to keep it from flopping side to side.
    T
    10th February 08
    St Peters, MO
    Quote Originally Posted by T-Bone View Post
    T
    I had actually thought of that after all was said and done so next one will be milled to accommodate that change.
