Results 1 to 10 of 15
    attworth's Avatar
    attworth is offline This member has been inactive for more than 1 year
    9th June 08
    Fort Worth, TX
    Knitted Garter Ties - Length?
    I saw a thread a while back about knitted garter ties. I was thinking I might kindly ask my wife to make some for me. Anybody know how long they need to be?
    Cameron
    22nd March 09
    Savannah, GA USA
    The traditional ties I purchased at the Scottish Tartan Museum are 36" long, but I do know that longer ones are made for those with large calves. The link below is to the page on their site where both the standard and longer ties are described.
    http://giftshop.scottishtartans.org/garters.html
    "There is nothing older, unless the hills, MacArthur and the Devil"
    http://www.lucastheatre.com
    19th March 09
    Astatula Florida
    Definately go longer, I made the mistake of going to short. Made some nice flashes myself, won't make that mistake again.
    babycakes's Avatar
    babycakes is offline This member has been inactive for more than 1 year
    5th May 09
    Fort Worth, Tx
    Quote Originally Posted by attworth View Post
    Apparently I'm making garter flashes! haha
    Anybody know where I could find a pattern or instructions?
    22nd April 06
    Cincinnati, Ohio, USA
    Twice the circumference of your leg at the top of the hose, plus enough to hang down below the cuff. Consider too the length of the fringe. You may want more or less of it in relation to the amount you reveal below the cuff.
    Rex.
    29th December 07
    KENT WAQ
    Quote Originally Posted by Rex_Tremende View Post
    Rex.
    Actually, I would DO THIS = take a pc of RIBBON,
    1. Wrap it & tie it as you wish ( note this discussion )http://www.xmarksthescot.com/forum/d...729/index.html ) Be sure to figure how much of the garter you want showing including the fringe ( note some only like basically the fringe to show. I like part of the garter to show also, especially on my more "fancy garters" (1'-1 1/2" =fringe )
    2. This then becomes your "pattern"
    Puffer
    31st May 08
    dc
    Remember that knitted garters stretch!!
    So account for that as well. You'll want it to go around twice plus the extra length that sticks out.
    5th November 08
    Marion, NC
    Quote Originally Posted by babycakes View Post
    Here goes:
    With a small size yarn, (such as fingering or sock weight), and a US size 2 or 3 double-pointed needle, cast on 1 1/4" worth of stitches. With a second DPN, knit those stitches, but don't slip them off the first needle. You now have two needles, with the original number of stitches on each. With a third DPN, begin knitting in the round over these two needles. You're making a long tube, or "snake". (It might be easier to divide these stitches onto 3 needles, and knit them with a fourth one.)
    When you've reached the desired length, work a two-needle bind-off -or- use Kitchener (grafting) stitch to close up the end. If you want fringe, use a crochet hook to pull a loop of yarn through an end stitch, pass the ends of this piece of yarn through the loop, and pull to tighten. Repeat for as many fringes as you want.
    In other words, you're making a very long, very skinny tubular scarf.
    I hope this helps.
    And welcome aboard, by the way, from western North Carolina, the greatest place on Earth!
    --dbh
    30th June 06
    Lotusland, Canada
    What some of us less talented members use is a Wonder Knitter. It is a modern version of what used to be called knitting nancies. I use a class 6 wool, very heavy. Instead of measuring, I count stitches, 375 for a large set and 325 for small. A large pair of ties will fit a 16" to 19" calf, the small works for 13" to 15". Once you've tried a few, adjust as needed.
    Gentleman of Substance
    attworth's Avatar
    9th June 08
    Fort Worth, TX
    Thanks for all the wonderful advice. Lookin forward to "helping" out with this.
    "Deep breath..."
    Cameron
  1. How do you tie your Garter ties
    By scotchmaster in forum How to Accessorize your Kilt
    Last Post: 2nd April 09, 05:10 AM
  2. Garter Ties!
    By Rob Wright in forum How to Accessorize your Kilt
    Last Post: 30th March 09, 11:01 AM
  3. Traditional Garter Ties
    By sirdaniel1975 in forum DIY Showroom
    Last Post: 3rd July 08, 06:08 AM
  4. Knitted Hose Ties
    By cacunn in forum DIY Showroom
    Last Post: 25th September 07, 04:58 AM
  5. Garter Ties
    By Southern Breeze in forum How to Accessorize your Kilt
    Last Post: 13th March 06, 12:07 AM
