Old 01-25-2010, 04:49 AM
Mipi's Avatar
Leather dying advice needed
Hi!
Few days ago, I dyed my old boots with Dylon colour for Leather. It should be cracks free result but....it's not. I'm not sure now where's the reason fro this. Would like to avoid similar results if dying sporran or even belt.
My opinion:
1. to use different (better) dye ... which?
2. not enough resting time between each layer
3. any other small tricks of great masters
Thanks for any advice.
Mipi
__________________
Old 01-25-2010, 06:28 AM
Tobus's Avatar
I admit to being a bit confused, as what you're talking about doesn't sound like dye at all. Are you talking about shoe polish, or a true leather dye?
Old 01-25-2010, 07:18 AM
Mipi's Avatar
It's not polish. It's leather dye for shoes and leather accessories, brand DYLON.
__________________
Old 01-25-2010, 07:21 AM
McMurdo's Avatar
Retired Forum Moderator
I've made a few belts and sporran straps and I use Fiebing's Leather Dye. I've never had a problem with it, if you can not find it locally you can order it from:
http://www.tandyleatherfactory.com/
__________________
Old 01-25-2010, 07:47 AM
Tobus's Avatar
Fiebings is what I usually use as well. It's an alcohol-based dye. There are also some oil-based dyes out there that will work too. It's a bit tricky to dye something uniformly, so you may want to practice a bit before doing it on something you really care about. They make a pre-dye conditioner as well, if you're having problems getting a uniform color. Then it obviously needs a good finish over the leather.
One thing I've found is that dyeing leather evenly is very much a function of the leather itself. Different tanning processes and different qualities of leather will make a huge difference. Cheaper leathers take the dye in a splotchy manner. Or if you're dyeing something that's already made/assembled (like a shoe), it may have various compounds already on the leather that will inhibit the dye from penetrating evenly. Oils, waxes, anything like that can cause a dye to soak in unevenly.
What confused me is your mention of "cracks". I'm not sure what you mean by that. Also, you mentioned "layers". Dyes aren't applied in layers. It soaks into the leather; it doesn't sit on top in layers like paint. When dyeing leather, you want to avoid having to come back with a repeated application if possible. It is difficult to get a uniform color once the original application has soaked in and dried.
Old 01-25-2010, 10:07 AM
escherblacksmith's Avatar
I also use Fiebings, and the only layering I have ever done was putting a dark blue stain on and then a black stain. Supposedly it ages better as the black is worn . . . haven't aged anything far enough to verify that yet.
Do you have pictures?
__________________
Barnett (House, no clan) -- Motto Virescit Vulnere Virtus (Courage Flourishes at a Wound)
Livingston(e) (Ancestral family allied with) -- Motto Se je puis (If I can)
Anderson (married into) -- Motto Stand Sure
Frame Lanarkshire in the fifteenth century
escher-Photoplog
Old 01-25-2010, 10:53 AM
svc40bt's Avatar
I am not familiar with the product you used, but it sounds as though it is one of the leather 'paint' products used to put a coating on lower grade leathers. I would suspect that the cracking is due to it being incompatible with whatever finish was previously on the leather.
I believe there are products designed to remove such 'dyes' but I don't know the name of any off hand. Perhaps one of our professional leatherworkers can help.
The products others have mentioned above are penetrating dyes, like wood stain. They would not work if the boots already have a coating type finish.
Old 01-25-2010, 11:12 AM
docr606's Avatar
dying leather
If you can get the old dye off, down to bare leather, dampen the leather evenly, let it dry a little, then use the Feibings and it should go on evenly.
Lotsa luck
__________________
Semper Fi
Old 01-25-2010, 08:50 PM
Ozark Ridge Rider's Avatar
Fiebings is the way to go. It will penetrate better than anything else I ever used.
Old 01-25-2010, 10:12 PM
blackbeard's Avatar
Dylon makes several dye products: fabric dye, leather dye and fabric paints. It is widely available in the UK and the rest of Europe. ( I think that it is a UK company) I have used their fabric dye and it is pretty good stuff. It sounds like you have their hybrid leather dye/paint product that is made for non porous surfaces. (although they market it for leather) From what I know their leather dye is a pretty good product. I would stay away from the stuff that you used on real, non patten leather. Because it is more of a paint than a dye, it can make leather and fabric stiff. (o k for a ladies hand bag, but not so good for shoes and belts) Stick to the Dylon leather dye and you should be fine. (although it is not available in as many colors)
As others have already stated, one reason for the cracking could be that the surface was not prepared correctly. Oils wax, and dirt will make the dye/paint sit on the surface instead of soaking into the leather. Also (just like wood stain and paints) if you think that two coats will be needed. Use two thin coats rather thick coats.
Good luck
X Marks Advertisers
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
re-dying leather question hylander DIY Showroom 7 11-04-2008 08:05 AM
Advice needed RamsayClanCommish Kilt Advice 13 07-19-2008 07:22 PM
Dying Leather Boots Birddog DIY Showroom 13 07-03-2008 12:09 PM
Advice Needed Dirka Skene Kilt Advice 13 02-02-2007 06:34 PM
Recommendation needed - custom leather tools Kilted KT General Kilt Talk 4 08-29-2006 09:29 PM
X Marks Sponsors
