Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
  1. #21
    22nd January 10
    London UK
    [QUOTE=acolander;848270]Perhaps I'm missing something, but why would one need to cut a hole through the outer material for the under apron strap slit, as opposed to making the slit between two pleats by not stitching that part together.. I have one of my kilts made in that way and what an excellent solution to the slits for the strap!
    Schiehallion kilted and true
  2. #22
    25th January 08
    Berkeley/Livermore CA
    Quote Originally Posted by acolander View Post
    Perhaps I'm missing something, but why would one need to cut a hole through the outer material for the under apron strap slit, as opposed to making the slit between two pleats by not stitching that part together...
    I think you means something like this:
    The above is a Tewksbury box pleat with the strap coming through between two pleats. A nice way of doing things if you can work it. Of course, if you already made a slit somewhere else...
    Perhaps all is not lost? The kilt strap on the other side should be close to the miss-cut. If the other strap partially or completely covers the hole, then there is not much to worry about.
    Lastly, like 'nassbarijpm' suggested, a reweaving service will do a nice job of truly fixing the hole, but it will be a bit pricey.
    Michael the Farlander
    Loch Sloy!
  1. My National Tartan Day Fashion Disaster
    By ali8780 in forum General Kilt Talk
    Last Post: 8th April 09, 02:56 AM
  2. Rest Room Disaster
    Last Post: 30th March 08, 05:34 PM
  3. My new $300 Disaster
    By Rex_Tremende in forum General Kilt Talk
    Last Post: 16th October 07, 06:56 PM
