Results 1 to 10 of 24
    31st May 08
    dc
    Talking My second attempt at kilt-making: X-Kilt
    As promised, here I show the X-Kilt that I made based on Alan H's X-kilt manual. Thank you Alan H!
    The fabric is just under 4 yds and made of polyester/cotton blend. It has a simple plaid pattern on it.
    A closeup picture of the top band and belt loop.
    You can also see the plaid design on the fabric (which I did not factor into the pleating) but I tried to align them as much as I could.
    A closeup of the cargo pocket.
    Link to pictures of my traditional design (hand-sewn) kilt:
    http://www.xmarksthescot.com/forum/m...552/index.html
    Question:
    What are your thoughts on the width of the apron, is it too wide for an Xkilt?
    (It's a little above 10". I've a 37" waist; 41" rump.)
    EDIT: A request for advice.
    I have a problem with the lower left side of the apron (on my left leg). It keeps wanting to curl up. I've already attempted to extend its A-shaping. That helped a bit, but still not enough. And I'm already going beyond the inch and half recommended A shape offset away from the "rectangle." Any advice?
    THanks.
    15th October 07
    Charlotte, NC
    That looks excellent. I can't really tell from the pic, but did you machine sew the waistband on both sides?
    As for the apron, I think it looks perfect, but I like the apron a little wider.
    27th October 06
    Snellville, Ga
    Well done sir! I too like the apron the way you have created it.
    31st May 08
    dc
    Quote Originally Posted by 12stones View Post
    Thanks! I did machine sew once through 1 waistband the layer and then once more through all the layers of the waist band and kilt.
    --I sewed one side first (one layer of the waistband strip) right side facing the outside of the kilt. Folded that over snugly to form the waistband and then sewed through all layers. In Barb's book, you handsew the final layer (that one in the inside of the kilt) so that no stitches show up on the outside.
    31st May 08
    dc
    Quote Originally Posted by Splash_4 View Post
    Thank you sir!
    attworth's Avatar
    attworth is offline This member has been inactive for more than 1 year
    9th June 08
    Fort Worth, TX
    I agree, the apron looks great. I put an 11" on my last x-kilt and it's still not as wide as the traditional I started on, (15" up top.)
    Edit: I forgot to mention. I've found that messing with the big pleat can help get that left edge down. Try ironing it much further than it actually needs to be and it should still hang correctly.
    Cameron
    2nd October 07
    Man, I wish I had some kind of talent... I can't even effectively press my own kilts, let alone make one! That thing looks great!
    22nd May 08
    Very nicely done!!
    Great job.
    31st May 08
    dc
    Quote Originally Posted by vmac3205 View Post
    Very nicely done!!
    Great job.
    Thanks guys! I'm enjoying making them. I have several projects lined up for friends!
    31st May 08
    dc
    Quote Originally Posted by attworth View Post
    Yeah, I've been trying to move the crease further in to the big pleat...
  1. My first attempt at kilt-making
    By meinfs in forum DIY Showroom
    Last Post: 14th July 08, 09:52 AM
  2. An attempt at a modern kilt. The 'Worky'
    By jkruger in forum DIY Showroom
    Last Post: 6th March 08, 02:26 PM
  3. My First Attempt At Doing the Kilt Justice
    By berserkbishop in forum Show us your pics
    Last Post: 18th October 07, 10:42 PM
  4. X kilt Second attempt
    By RK-REX in forum DIY Showroom
    Last Post: 4th July 07, 03:56 PM
  5. First attempt for hockey kilt
    By possingk in forum DIY Showroom
    Last Post: 28th January 07, 10:28 PM
