Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
    29th January 06
    Asheville, NC
    Quote Originally Posted by fluter View Post
    Almost forgot my most pressing question: with a 9-10 inch over apron, what is optimum size of the under-apron??? I'm about the size of the hypothetical guy in Appendix 1 diagram, but was not very sure what was included in the 16 inch allocation for the under apron. I extended a bit with a deep (6") apron pleat, then made the apron 10 inches wide. I'll wear it a while and see what happens.
    I'd suggest that you make the under apron at least long enough to extend past your left thigh while standing. If you make it much shorter, you'll find that when you sit down the aprons will part ways in the middle and create an opportunity for major exposure.
    24th November 06
    Oregon
    Fluter,
    It looks great! You have made the perfect first X-kilt: good enough to wear with pride but with enough little "imperfections" to learn from and to make you restless to make the next X-kilt. Bravo!
    Moosedog
    On edit: ditto what tartan Hiker said. Also I often find that when playing with the width of the overapron I end up needing to secure it not only at the waist per Alan's manual but again 4-5 inches further down. I know, it's like the dreaded "unnecessary second hip buckle" on a traditional kilt. But whereas with a wide apron (approaching 1/2-way around you) the second buckle is superfluous, on narrower-aproned kilts I find they often don't hang and move right unless I secure it, either with a second bit of velcro (practical) or a strap and buckle (looks sharp.) This is aggravated is someone with muscular thighs. That's why kilts with really narrow aprons (UK or AK) have additional securing points via snaps.
    It looks as if you built enough taper in to minimize this on your first one, just a heads up for the next.
    Quote Originally Posted by Moosedog View Post
    Fluter,
    Moosedog
    I've taken to stitching down the left hand edge of my over-aprons on my X-Kilts to the fell line, for exactly these reasons.
    29th April 07
    Columbia, SC USA
    Yup, I did that, too. I was considering adding a velcro patch at the right, as Moosedog suggests.
    Thanks to all for the ideas and encouragement!
    29th January 07
    San Jose, CA
    There are some faults, but this is why we learn with inexpensive cotton! I understand my brethren's references to kilts for yard work! but as a first project, I feel good about it.
    As you should-this looks great!
    I have pretty good sized under-apron pleats on both sides (5 and 6 inches). Perhaps a bit more would be better.
    About half the size of the over apron on the left seems to be good, but deeper is fine-never hurts to have more coverage!
    I find that the underapron should be about half again as wide as the overapron if you want to avoid embarrassment!
    As a woman, I find that if one sews down the entire fell line it is too tight at the hip, but for a man, I imagine this works out fine.
    Be well,
    The Flame-Haired Celtic Amazon Goddess
    "All shall love me and despair!"
    31st August 08
    New Mexico
    Nice kilt!
    Many is a word that only leaves you guessing.
    8th May 08
    Jacksonville, FL
    That looks good
  1. Blazn tackles 2 X-Kilts
    By BLAZN in forum DIY Showroom
    Last Post: 14th August 07, 09:37 PM
  2. Tailor in Minneapolis, MN
    By Heavy Gamer in forum Kilt Advice
    Last Post: 6th June 07, 02:36 PM
  3. Tailor in Minneapolis, MN
    By Heavy Gamer in forum Professional Kiltmakers Hints and Tips
    Last Post: 24th May 07, 08:06 AM
  4. My tailor hooked me up!
    By Sciuropterus in forum How to Accessorize your Kilt
    Last Post: 30th December 06, 07:35 AM
  5. Oregon Tailor Supply Co., Inc.
    By Kilted Taper in forum Professional Kiltmakers Hints and Tips
    Last Post: 31st July 06, 12:18 PM
