Page 1 of 7 123 ... LastLast
Results 1 to 10 of 65
Thread: Pour one for me
    28th October 05
    Rocky Mts.
    Pour one for me
    I' started making another sgain dubh and thought that some of you might like to see how to pour a metal bolster. Its fast,easy,cheap,and doesn't look bad either.
    15th July 07
    California
    Nice looking blades! But you mentioned "how to pour a metal bolster..."
    Well?
    28th October 05
    Rocky Mts.
    Raw materials
    the blades are high carbon from sheffield
    the bolster will be poured from 50/50 lead/tin solid core solder
    I also add more solid core tin solder to make the bolster harder and brighter
    you can use antler or wood for the handle,it will work with anything except plastic
    28th October 05
    Rocky Mts.
    lay out
    15th July 07
    California
    So that's basically a tin/lead alloy?
    Neat!
    And it's hard enough?
    15th July 07
    California
    I know, I know! Patience!
    28th October 05
    Rocky Mts.
    cut tang
    drill handle
    square up face of antler
    28th October 05
    Rocky Mts.
    lead tin alloy is poor mans pewter
    Its plenty hard and pour smooth and easy
    28th October 05
    Rocky Mts.
    leave the blade extended out to the desired bolster thickness don't go more than 3/4 inch with this method
    cross pin blade into handle
    28th October 05
    Rocky Mts.
    wrap masking tape around the base of the handle.ido about ten wraps
    this will alllow for shrinkage of the metal and require the metal to be filed down to the horn
    I also wrap the blade almost to the bottom of the blade blank to aviod tool marks when filing
