Old 12-30-2009, 09:23 AM
Drac's Avatar
Putting together a sgain dubh
Morning all,
Ordering some materials for a hunter style knife. I have a sambar stag tine coming in for the handle. I've seen these used before and giving their history as a hunting knife it makes sense.
Now researching them to see how some are set up all I can find are ones that use rolls. Does anyone have or know of examples that use tines?
Here is a sample pic of what I'm ordering -
Thanks,
Jim
__________________
I cook with a flair for the dramatic,
and depraved indifference to calories
Old 01-21-2010, 12:59 PM
Drac's Avatar
No one?
__________________
Old 01-21-2010, 01:30 PM
cavscout's Avatar
I'm not exactly sure what you are asking for. There are several threads here about making sgian dubhs where the blade has a tang on it. Are you asking about how to mount the blade into the handle?
Old 01-21-2010, 02:30 PM
Drac's Avatar
This it a roll
This is the part of an antler between the base ant the tip (tine) but doesn't have a branch.
I was looking for examples that use the tine part for a handle.
Jim
__________________
Old 01-21-2010, 02:51 PM
cavscout's Avatar
Try searching for "antler tip knife"
I found a bunch of sites like this one
http://rehknives.blogspot.com/2009/0...micarta-4.html
Old 01-21-2010, 03:03 PM
Drac's Avatar
Thank you!
I've learned over the years sometimes it's just how you phrase you searches.
Jim
__________________
Old 01-21-2010, 07:04 PM
Ozark Ridge Rider's Avatar
I have made several small knives (not exactly sgians but similar) using tines. I would suggest using as much tang on the knife as you can readily drill out a socket for, and using a piece of brass or aluminum for a bolster and epoxy it all together.
If you like you could drill through the antler and tang a short distance down for a cross pin (which should probably match the bolster or guard, imho).
It's a pretty simple process.
Dan
Old 01-21-2010, 07:16 PM
Drac's Avatar
I've done couple hidden/stick tangs in the past. I'm more curious on what to make them look like.
A nice trick told to me by another knife maker is to fit the blade and handle together and drill the hole for the pin. After heat treat when you go to assemble the pieces together insert a piece of spacing material, usually vulcanized paper about .02" thick. This with the added glue is just enough to move the hole in the tang slightly off but not to far. When the pin is forced in it pulls the blade tighter against the guard.
__________________
Old 01-21-2010, 09:14 PM
Good idea. Mine are usually epoxied tight, though.
X Marks Advertisers
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Putting together a Jacobite impression EDWARDI Historically Made Kilts and How To Wear Them. 7 10-15-2009 11:34 AM
Putting new forum members in a Catch 22 Streetcar Miscellaneous Forum 22 07-20-2009 05:45 PM
Putting an antler on a knife James MacMillan DIY Showroom 12 05-22-2008 05:10 AM
Putting the kilt to work Graham Show us your pics 19 09-05-2006 05:15 PM
putting on an avatar? akaussie General Kilt Talk 14 08-25-2004 07:40 AM
X Marks Sponsors
