27th August 10, 02:00 PM
27th August 10, 02:41 PM
Return it to a straight piece of material and use it as a plaid?
Anne the Pleater
27th August 10, 03:23 PM
Anne the Pleater
...or a picnic blanket.
--dbh
27th August 10, 03:32 PM
Lay it across the back of your couch.
29th August 10, 08:19 AM
Currently in the process of returning it to a straight piece of material. A plaid ( (or picnic blanket or couch throw) would definitely be the easiest options.
I'm still toying with the idea of using a different colour of fabric for an underapron, and thereby making up the yardage for a casual/contemporary box pleat kilt...
Or a waistcoat? And a necktie?
- An t'arm breac dearg
29th August 10, 08:57 AM
The weather has changed here in the South of England, wind and cold rain - after a long hot dry summer suddenly the idea of having a nice warm plaid neatly folded on the shoulder and ready to insulate seems a really good idea.
If your material was a bit longer and wider I'd be with you on the kilt, but I think it is just that bit too skimpit.
Anne the Pleater
29th August 10, 11:57 AM
Using different matching fabric for under apron is not bad idea at all. But consult your lass on all possibilities.
29th August 10, 01:33 PM
Sounds like a lot of work to me...If it's a meaningful tartan, save it for your daughter (if you have one or hope to someday). A tie might be something easy to make, and something that you might get some use out of.
29th August 10, 08:45 PM
The kilt-skirt has been disassembled and resulted in a piece of tartan 8' 8" x 20". The waistband produced a small strip measuring approximately 37" x 4".
If I wear a kilt at my p@nt$ waist, 20" length is actually ok for me, so there is still some small hope that this could be made into a contemporary casual kilt. Now, assuming that it was possible, who could I get to do that?
My lass helped take it apart though and she is starting to eye the fabric with thoughts of another mini-kilt for her. I wouldn't argue with her if she claimed it
There is no selvedge and I preserved the finished fringe. If I were to use it as a blanket/table runner I'd still have to have to do something to the raw edge...
Here are a couple links to descriptions of the tartan for anyone interested. It has been the official tartan of the Canadian province of Alberta since 1961. Interesting to note that the sett is very small; it's only 3.5".
http://www.tartanregister.gov.uk/tar...ls.aspx?ref=39
http://culture.alberta.ca/about/emblems/tartans.aspx
29th August 10, 08:58 PM
Have you thought of a waistcoat? and the thin strip could go to good use has a hat band for a pair of hats, a his and hers pair of hats might be fun.
Just brain storming. but if you plan on a kilt in that tartan some time anyway then getting a tank in that tartan it would be nice to have a matching waistcoat.
By cavscout in forum Miscellaneous Forum
Last Post: 17th November 09, 05:40 PM
Last Post: 26th January 07, 05:29 AM
By Iolaus in forum Miscellaneous Forum
Last Post: 22nd December 05, 10:07 AM
Last Post: 27th February 05, 05:41 AM
