Results 1 to 6 of 6
    23rd January 08
    Memphis
    Rowan wood sgian
    I finished this sgian recently. The wooden portion is a branch collected from the mythical rowan tree in the Highlands. This wood is every bit as tough as Tennessee hickory.
    The snakehead end is a stock cast I made from a grey ratsnake found dead long the roadside last summer. I used poured pewter to fashion the bolster and learnt the technique from others here.
    The business end is 4140 steel sgian blade purchased from Track of the Wolf almost a year ago. I left the blade shiny & a bit polished, though may change that to a browned one.
    This one elicits a lotta interest.
    29th January 06
    Asheville, NC
    JS...great job. That's a really nice way to utilize the casts that I never really considered.
    23rd January 08
    Memphis
    << That's a really nice way to utilize the casts that I never really considered. >>
    Thanks verra much. The one you fashioned actually gave me the idea.
    Over the weekend I picked up a smallish DOR Nerodia. I didn't really study it much, but wrapped it in plastic and chucked it in the freezer.
    steve
    29th January 06
    Asheville, NC
    Looks like you smoothed the cast's surface a bit. Did you use fine sandpaper, steel wool, or something else?
    23rd January 08
    Memphis
    << Looks like you smoothed the cast's surface a bit. Did you use fine sandpaper, steel wool, or something else? >>
    Not much, but I used fine grade emory board and the polishing side to buff out some sheen. Also, you can see some smoothing in the transitional area between wood & casting. Used a Dremel tool there.
    As for wood finishing, I learned a long time ago if that wood is sanded almost to it's finishing state and then wetted, the grain is raised. Repeat sanding and wetting until the grain no longer rises. This could be 6-12 times, but once done it makes for a very refined surface.
    attworth's Avatar
    attworth is offline This member has been inactive for more than 1 year
    9th June 08
    Fort Worth, TX
    Beautiful. I still have a few of your snake heads that I need to fashion into blades.
    Cameron
  1. Any Wood Badgers out there?
    By Tatonka in forum Miscellaneous Forum
    Last Post: 6th April 09, 04:31 AM
  2. Wood cantle?
    Last Post: 13th January 09, 12:01 PM
  3. Ivy wood Sgian dubh
    By Arlen in forum DIY Showroom
    Last Post: 17th July 07, 11:17 AM
  4. drying wood
    By auld argonian in forum DIY Showroom
    Last Post: 27th April 07, 12:22 PM
  5. Wood Kilt Pins
    By Daneel in forum How to Accessorize your Kilt
    Last Post: 9th November 04, 06:55 PM
